S-AWC % of torque split
Old Nov 10, 2008 | 10:55 AM
Miles08WWSSSX's Avatar
Okay i used the search first thing but came up empty handed. So Here's my question does any evo x owners know the percent of torque split that each setting is programmed (meaning Tarmac,Gravel, and Snow) too operate when selected. the owners manual just states at what condition to use each setting but that's about it.
I was just curious if the system it like my twin brothers Subaru sti any input is appreciated.
thanks miles
Old Nov 10, 2008 | 11:06 AM
Rguy's Avatar
The AWD system in the X is either 100/0 or 50/50.
The modes just change when the ACD clamps i believe.
Old Nov 10, 2008 | 12:03 PM
08EvoXGSR's Avatar
tarmac is 40/60 front to rear, gravel is 50/50 snow is biased 60/40....or there abouts
Old Nov 10, 2008 | 12:38 PM
Rguy's Avatar
Not true. read my post above.
Old Nov 10, 2008 | 02:06 PM
Red Dragon's Avatar
i dont think it is the same as the subaru awd system.
Old Nov 10, 2008 | 04:16 PM
sl0ev0's Avatar
no difference in torque split guys. tarmac, gravel, and snow are inputs into the acd, and i believe it only changes the lock-up of the center dif
Old Nov 10, 2008 | 08:19 PM
Clark_Kent's Avatar
Everyone should cite their source. Lots of misinformation in this thread.
Old Nov 12, 2008 | 08:29 AM
Thanks for the input guys and or gals, you'd think Mitsubishi would give a detailed description besides what road condition but anyways thanks.
Old Nov 12, 2008 | 09:41 AM
pltek's Avatar
tarmac/gravel/snow, thats 3 and not 2 split settings
100/0 means you are dealing with a front wheel drive car, virtually
where did you get that info?
Old Nov 12, 2008 | 11:33 AM
Rguy's Avatar
All Evo's are essentially FWD until the ECU determines that conditions warrant power to be sent to the rear wheels.
Old Nov 12, 2008 | 12:17 PM
AsH74's Avatar
All credit goes to the OP of this sticky.
https://www.evolutionm.net/forums/sh...ight=acd+works
Side note: the 03-04 Evos had no active center differential, similar to the 1G and 2G
DSM's which sported a VC center diff.
Old Nov 12, 2008 | 12:29 PM
murlo26's Avatar
So it is always 50/50 and just changes timing, thats what I was told when I made a post about something similar and this link appears to agree with it.
Old Nov 12, 2008 | 12:50 PM
Rguy's Avatar
You can read about it here.
http://www.caranddriver.com/reviews/...ferent_feature
"The Mitsubishi, on the other hand, never sends the majority of engine torque to the rear axle. Instead, it can send all the engine torque to the front wheels or 50 percent of it (using an electrohydraulic clutch on the center diff). So the Evo varies the front-to-rear torque split between 100/0 and 50/50. "
Old Nov 13, 2008 | 06:08 AM
KPerez's Avatar
Is this true for the EVO X? The 2005 article refers to earlier EVO's.
Later, Ken
Old Nov 13, 2008 | 10:00 AM
criptballer's Avatar
i work for a mitsu dealership and to my understanding of how the Lancer evolution trainer representative from mitsu explained is like this.
tarmac= 20/80 rear
snow= 90/10 front
gravel=50/50
i have found this in a lot of technical reading from mitsu as well.
