ASC service light with stealth fx bov
Boost increases seem to be the main culprit in many cases, and everyone sets their MBC or EBC (or value sin the ECU with a reflash) to different settings, so maybe that's why it seems to vary so much. Driving style would also be a factor. People who "lug" the car by running full throttle in a high gear create higher load on the engine which can cause overboosting. Who knows? There are way too many possible explanations for why one person's setup would cause an issue when another person's doesn't, even when they are making similar power.
Actually, I did find out that Mitsubishi is releasing an update for the software on the SAWC system, and one 'fix' is supposedly the random ASC lamp. This came from a Mitsu dealer, and a bulletin is pending according to the service manager.
:::STARES at ASC lamp, and yells, "Make it stop, make it stop, make it stop!!!!!:::
Lets see if it comes to fruition. It does sure seem that some cars are more sensitive than others.
For sure! I noticed when I run 50/50 E85/93oct that the lamp hardly ever comes on. I'm having the car tuned for higher boost & E85 fuel, so I can run it harder when I want to, and still not have to spend big money on mods. Have to see how the ASC freaks out once it's done on Monday.
bah...i'm having the same issue after my stage 2 + aem reflash using cobb ap...
that light is freakin annoying...i have a stock bov...when i turn off the engine and turn it back on...the light goes away...only to come back on shortly after, i reset the ecu and the light stays off for good...but the car runs like crrrrrrrrrrrrrrrrrrrap! lol
i reflashed it again...and the ligiht stayed off for a while...several hours infact...i thought the problem was going to be solved...nope...
in regards to the random asc service light fix from the dealers...does anyone have an update on that? is the fix/patch released yet?
-howie
-howie
landis507
24
Feb 18, 2008 01:32 PM
SJCoruja
Nov 2, 2005 08:57 AM
lemacfar
15
Feb 19, 2005 03:33 PM
