ETS NEW O2 Housing !!!
Old Dec 11, 2008 | 08:58 AM
  #31
ETS Michael's Avatar
Originally Posted by gunzo
ETS Fanboi
Can you put back the lower heatshield?
Really close to the steering rack
Consider putting a tongue divider between the wastegate and the turbine?
The lower heat shield will not bolt back on. You can still use the upper factory heat shield.
The wastegate and exhaust are already separated from the factory and do not need a tongue divider.
Ported FP Evolution X Housing
Some of the other companies have you use the factory gasket, which allows gasses to move between the exhaust and the wastegate dump. We provide a gasket that truly separates the wastegate and the exhaust. (See Above Pic)
Originally Posted by Talon_66
Wow, I love the looks of that piece!
Originally Posted by mrfred
Very very nice. Just wondering though is the WG pipe can be angled to merge with the a little less angle.
The current angle allows for a smooth transition. We could change the angle, but there will be no additional gain.
Thanks!
Michael
