Which BOV you recomend?
Old Dec 29, 2008 | 09:04 AM
philamthebest's Avatar
Hey just wondering what BOV you guys recommend for the MR? I was looking at the Greddy RS or RZ. What do you guys think?
Old Dec 29, 2008 | 09:07 AM
TxEvo8's Avatar
Is your stocker leaking?
Old Dec 29, 2008 | 09:30 AM
Jedi_Gill's Avatar
FCOTM Winner
He's telling you that because honestly the stock Blow Off Valve, is the best one until you start hitting over 400 WHP. If you're going to say something about how you want the psssssshhh noise then change the air intake on the car to a cone filter. Other than that get ready to be flamed. A moderate upgrade would be the Metal Stock MR Blow-Off Valve; if you don't already have one.
Old Dec 29, 2008 | 09:40 AM
Spookpur's Avatar
Old Dec 29, 2008 | 09:58 AM
Yearlongstorm's Avatar
I have the HKS SSQ. No problems with that either and I VTA. I would go with something thats already been on the market for awhile and tested to work.(with and without a rec circ kit)
Old Dec 29, 2008 | 10:06 AM
Smike's Avatar
There is always problems with running VTA on a MAF (metered) setup (aka OE Evo's).
Stick the the OE unless it is leaking on you.
Old Dec 29, 2008 | 01:30 PM
I guess i will keep it stock then... problem solved.
Old Dec 29, 2008 | 02:20 PM
Iceman5's Avatar
keep it stock!!!
Old Dec 29, 2008 | 07:59 PM
BKaulitz's Avatar
get a HKS
Old Dec 30, 2008 | 12:24 AM
LaNcR06's Avatar
Its your car so if you want to spent to money thats on you. performance wise dont think it would make a difference what so ever. If you want it for look appeal or sound then the HKS is for you. With the sequental you can dial it and change the sound.
Old Dec 30, 2008 | 12:40 AM
nawaz's Avatar
the last time I read about getting a blow-off valve for my Evo, I read that it wouldn't make a difference and it possibly could affect/alter the performance a bit. I heard that Evo's don't work well with aftermarket blow-off valves......correct me if I'm wrong.....thank you.
Old Dec 30, 2008 | 01:30 AM
skatermsmn's Avatar
I had a greddy type rs on my 8 and it would die all the time when I came to a stop,I swapped it out for a metal 9 bov and the problem was fixed
Old Dec 30, 2008 | 01:38 AM
LANCEREvo9MR's Avatar
yeah keep the stocker it holds up really goood if u want the noise change the intake to a cone yo
Old Dec 30, 2008 | 01:57 AM
monkey_187's Avatar
Keep the stock one unless it is leaking or you have the need for a new one, i.e your runnig an insane amount of HP.
Old Dec 30, 2008 | 06:36 AM
GrkBallaG's Avatar
I got the Go Fast Bits one, set on full recirc, sounds way better than the stocker and i have had zero promblems.
