Blouch Dominator II vs FP Red - Pros/Cons
Ready to pull the trigger on my next round of upgrades, but need some more info regarding the path for the turbo. I have read countless posts about both the Blouch Dom II and the FP Red and all seem to get very positive reviews. What are the real differences between the two in real world terms.
Is one better for pump gas?
Is one better at spooling up?
Which is closest to stock spool?
My personal objective is to have a fast reliable pump gas X. I prefer stock like manners but with power upon desire. I have no desires to track the car either drag or on a road course. Driveability is very important for me. The turbo install would include fuel injectors and a re-tune. Any help is greatly appreciated. Those with personal experience with either on the X please post your comparisons in regards to stock driveability.
The better question would be, what are the mechanical differences? I think the Blouch uses Garrett compressor and turbine wheels from the GT3076 (76mm compressor, 60mm turbine). I don't know what size wheels are in the Red. I would add the third option, one of the two Garrett options (3071 or 3076).
Both seem to spool up very similarly but the Red outflows the Blouch turbos by a large margin. Expect full boost around 3800ish RPM give or take. Injectors required with eitehr one. It's a no brainer to go with the Red considering the pricing is pretty close. I'd never deal with Blouch ever again, but that is another story. . . .
Im not saying I dont belive you. just looking for proof rather than a bias opinion. Which is likely what the OP is looking for also.
So anyone else with any info regarding the spool up performance between the two? If spool up is the same, the obvious choice would be the FP Red. Its less expensive and has more power potential. The other consideration is support from the vendor. Am I missing something obvious? Why is there such a difference in price between the two? They both use a stock housing but with different wheels?
If the FP Red and Blouch spool up at 3800, where does stock spool at?
So you're saying that the FP Red flows more than the larger framed FP HTA GT3076R, which has the same internal upgrades as the FP Red and is rated at about 57 pounds per minute?
The FP Red flows about the same as the Blouch Dom II, Mr. Guru. You're one serious BS'er.
FP Red:
http://store.forcedperformance.net/m...Code=NTEVOXRed
HTA GT3076R:
http://store.forcedperformance.net/m...e=Lancer-Turbo
FP Red:
HTA GT3076R:
If that's true, that would imply that the FP HTA GT3076R will produce over 650whp? Wow. That would be a turbo that spools faster than a standard GT3076R that produces more power than a standard GT35R. That's mind blowing.....Lies.
Here is a graph of an FP Red on my car, the tune is very conservative as I was headed to California to run it on track for the first time and needed it to be rock solid... A/F ratio's are in high 10's.
Mods:
FP Red
3" TBE
R/C 780cc's
AMS Intake
AMS Intercooler
AMS Intercooler pipe
110oct tune
FP Red vs. Stock Evo X:
Mods:
FP Red
3" TBE
R/C 780cc's
AMS Intake
AMS Intercooler
110oct tune
