kelford 214-b vs cosworth mx1
100% stock motor (we have never had the valve cover off)
Exedy twin disc
walbro fuel pump
1000cc injectors
Ecutek
cosworth cams and springs are in took all of about 3 1/2 to 4 hours from start to finish
ups dropped off fp red this moring going to be working on that and the install of the avcr to day and injectors should be here tomorrow then off to dynoformance for a retune
the only thing im fighting in my head right now is weather to spary meth with this setup or just run 93 pump I and sparying meth now but not sure weather to keep it or not
If anyone feels like chimming in with there thoughts that would be great
How did you replace the springs so quickly? Did you pull the head off or did you pressurize the chamber and take the springs off? Also, did you have to use the special service tool to depress the timing chain tensioner or did you just use a pry bar?
fp red has arived and is installed !!!!!
thx alot fp for the fast service you guys rock
injectors will be here friday
and i am set to go to dynoformance next sat the 7th for a retune
Well i guess ill have to give the tunner a call got a chance to go out and drive the car last night and im getting a check engine light p1235 and a p0137 now
the tuning didnt produce what i would have liked to see but we put a conservative on it
370ish hp 360ish torque on pump with no meth
ran out of time to try to get meth tunned
