kelford 214-b vs cosworth mx1
I have seen a few posts of people that have used the cosworth mx1 cams
has anyone tried the kelford 214-b cams yet?
Im in the market for a set of cams and not sure what ones i want.
If you guys/gals have any input or Pros and cons of either brand please chime in
the cams are cosworth intake and exhaust 266 duration intake lift is 10.8 mm
exhaust lift 10.4
the kelford are intake 270 duration 11.3mm lift exhaust 262 duration 10.35mm lift
onnce again thx for the input
exhaust lift 10.4
The Kelford 270 looks badass, but I don't have any personal experience. I know this requires an additional valvetrain upgrade ($250), which is probably a good thing. Cosworth and the milder Kelfords are limited by the fact that they are designed to work with the stock valve springs, etc. That said, Cosworth is more 'proven' IMO, and already has some great numbers posted from several sources.
Another issue is that this camset is designed with upgraded turbos in mind. Problem is, if you go that route, you'll need an upgraded fuel pump too, which isn't readily available for the X yet. stock fuel pump is will limit you around 400-425hp. a turbo and these cams should put you well over that mark with supporting mods.
im sry i forgot to list mods
1 of the 2 cams listed above
fp red on order
deatschwerks 800 cc injectors
tt hard pipes
ur full turbo back exhaust
meth injection
and a ecutech tune
and valve springs reguardless which cam i go with
and as soon as a fuel pump that fits right that will be next
now with my mod list what cams would you guys/gals think best fit my app
fp red on order
tt hard pipes
meth injection
and a ecutech tune
Darryl
www.ultimate-racing.com
Actually, we've had our Walbro 255 Install Kit available for the Evo X for a few months now.
Darryl
Darryl
Thanks for the heads up. What HP level will the 255 support?
related question on the topic of cams: would running them with an upgraded turbo on pump gas show the same gain if you're already pushing the limits of 93 oct, or would race gas be needed to get the most out of them?
well i went ahead and ordered the cosworth mx1 cams and springs dhould have them monday and in the car by mid week with the fp red and injectors then off to the tunner will post results when im done
cant wait to see what numbers i put down on pump gas vs pump gas with meth
I was told by a vendor here that the 214-B is made for large frame turbos and will not be a benefit on a small frame turbo like the FP Red (or stock). I would still be interested in seeing some numbers on these, but if this is true, I guess the Cosworths may be our best option.
Lots of backpressure and high duration cams are a no-no because you'll get reversion. So that leaves two options that I can think of: wait for the Garrett bolt-on turbos, or buy a full turbo kit that uses a bigger turbo (requiring a new exhaust manifold).
I would also be hesitant to use the larger overlap and lift Kelfords with a stock frame turbo like the FP Red. All these stock frame turbos with bigger wheels are mainly limited by one thing, the small turbine housing. Putting in a bigger turbine wheel helps, but the small turbine housing will still create a lot of backpressure.
