check engine light
If you buy a testpipe without a CEL fix, all you need to do is buy spark plug anti-foulers and drill one out with a 1/2" drill bit. You then put that on the o2 sensor. Next, you put the other anti-fouler on top, then screw the whole thing in where the secondary o2 sensor would go.
The purpose of the secondary sensor is to basically tell your ecu that there is a cat on the car. The defouler only allows so much of the exhaust gas to reach the sensor, therefore making it think there's still a cat on the car.
