So my clutch finally went......
-The pedal pressure is heavier compared to stock
-Grabs much harder, but still breaking it in so i don't know how much greater it is then stock..im sure theres a huge difference..i'll let you guys know in a couple hundred more miles
No, I'm not joking about the ACD line. It must be removed from the top of the tcase to access one of the 17's. And there are ways around having to bleed the system (crimping the line).
Evo4u2envy- What's the process like, breaking in a performance clutch? No downshifting, and basically trying and take off as smooth as possible right? Do you give it any gas when taking off cause I had a stage two exedy clutch and blew it in 6 months and had to replace it again, I don't know what I'm doing wrong with my driving. How do you make these things last?
