UR FMIC for Evo X!
For a relative comparison and your reading pleasure see: https://www.evolutionm.net/forums/ev...rcooler-2.html. The prices for these FMIC are dated so please be advised.
Later, Ken
Later, Ken
This looks awesome, and 20 whp sounds almost too good to be true. I am seriously considering this, but I just have a few questions. For starters, are hot spots an issue with a core this thick? Also, how is there no loss in spool? On the 9, and most turbo cars in general, larger cores take longer to pressurize and thus increase lag. The 9 and the X both use the exact same core, just with different end tanks obviously, and ICs on the 9 didn't make any more power (until giant turbos were used) and just increased lag. How is the X able to overcome this? I am guessing that it possibly has something to do with the fact that the compressor housing of the X's turbo is insanely close to the manifold, which tends to heat up the air going into the ic a bit more and thus heat soak it a bit (at least this is what perrin's testing showed). Is this a possible explanation as to why ICs actually make a difference on the X? Thanks for any info.
Later, Ken
