To test pipe or not to test pipe?
I use the Blitz, SBC iColor, and a manual boost controller, both of which are amazing and i love having them. the Blitz is slightly expensive, and you can find the same thing from another company at a lower price....
The only problem is that I don't live anywhere near a reputable tuner. I live in SC.
Jestr- FL, 6 hrs away
Buschur- OH, 11-12 hrs away
AMS- IL, 15 hrs away
No one around here knows how to tune, at least from what I've heard. It's a possibility that I might drive to Buschur this spring or summer. But it's still a long trip regardless.
I personally haven't heard of people having problems with untuned test pipes but I guess wait until someone says something for sure.
You can run a test pipe untuned. No problems...
A resonated test pipe will only make it marginally quieter. in fact a good HFC is not that much different in noise than a test pipe. meaning good, as in flows well. a HFC that doesn't flow well, may be quieter, but then will rob you of power.
just an FYI - I am running a test pipe.
The test pipe does add a little noise, but you do get a performance gain anytime you remove a restriction out of the system. We sell a test pipe for $259.00 which includes a J-style o2 bung that prevents any type of CEL.
The pipes are designed for off road use, so be careful when it comes emission time.
Thanks!
Michael
Thanks!
Michael
I don't care if it increases noise at all. In fact, I wouldn't mind if it was a little louder. The only thing I do care about is hitting fuel cut at WOT, like when racing someone for instance. But I suppose if you don't gun it in certain gears you would avoid fuel cut. But what's the fun in that?
i just put on the UR resonated test pipe... is amazing! you will need to head the o2 sensore with map gas, this was not a fun job! i used PB blaster also but the map gas was sufficient....
