Manual or Electric boost controller
Old Mar 15, 2009 | 12:49 PM
Evo a Mula's Avatar
This is very complex to me I'm my findings shops like ams, BR, ets, & much other use MBc on the evo X & get real good outcomes electric or manual like if I was yo get a manual boost controller set it to 25 psi & never touch it on stock turbo that would not be safe? Mabye its just me but I have not seen to many people use & electric boost controller on a evo X yet
Old Mar 15, 2009 | 01:50 PM
jmorris1027's Avatar
Shops like ams or whoever else will make crazy power no matter what they use for a boost controller lol. if you want a mbc so bad just buy one already. there cheap and effective, however low tech at most.
Old Mar 15, 2009 | 02:25 PM
Evo a Mula's Avatar
^ your not understanding what i am saying im just looking at what they use and mbc is what they use to be honest i love the numbers you made by just using the ecu honestly it is just confusing to me its almostlike theres two sides to it
Old Mar 15, 2009 | 02:33 PM
MrEVO313's Avatar
mula, you talking about MBCs for the evo X or evo IX??
Old Mar 15, 2009 | 02:45 PM
Evo a Mula's Avatar
^ for the x
Old Mar 16, 2009 | 06:32 AM
MrBonus's Avatar
Shops use aftermarket boost controllers most likely because they are testing aftermarket parts at a myriad of boost levels with different kinds of fuel and tunes and an aftermarket boost controller is the simplest, most efficient way to alter boost levels on the fly.
Old Mar 16, 2009 | 06:46 AM
KPerez's Avatar
Originally Posted by MrBonus
Agreed. Plus, I like to know that my boost control is tied into the ECU if the car were to ever enter limp mode.
You are right on this!
Later, Ken
Old Mar 16, 2009 | 06:49 AM
gunzo's Avatar
1 simple answer for you then
Not many people know how to tune the X with electronic controllers ..
You're more than likely to throw a CEL when you go part throttle full boost as commanded by the EBC ..
Thats why everyone says use ECU controlled boost .. less headache ..
Old Mar 16, 2009 | 11:42 AM
Evo a Mula's Avatar
i understand but is there any downside to manual boost controllers on a stock x like if i was to get onewhat is a good safe place to set it
Old Mar 16, 2009 | 02:28 PM
irok1evo's Avatar
Hello guys & gals! Comming from the wrx to the evo I am n da same boat. I have never used a MBC I HAVE ALLWAYS USED A EBC. The reason is so many like 5th gear pulls part throttle and a host of other reasons. This is just me I am NO TUNNER by far. It allways made me fell a lil more better knowing that $500 thing wit the nice lights will cut boost at my set max. I have used the avcir on my first wrx and don't get me wrong it's nice, but way to much for a first. I will not buy one again knowing what I no now. The best one I used was the blitz I forget the model but I had the ID unit to match. ( this was back in 02,03). I am looking to get the new model it was just so simple to use. It had boost set for speeds, that will help on high way pulls. I am at and would love to talk more but I got to go. Good luck
Old Mar 16, 2009 | 06:39 PM
Noize's Avatar
EvoM Administrator
ECU controlled boost. Better control, control in more points, protected.
MBC and EBC on stock turbo are a total waste.
Old Mar 16, 2009 | 07:29 PM
Evo a Mula's Avatar
so for stock turbo boost controllers are bad but lets say you got the fp red turbo a boost controller would be better??
Old Mar 16, 2009 | 09:22 PM
gunzo's Avatar
Erm .. lets debunk that myth ..
Its NOT easy dialling in the boost you want with ECU controlled boost.. call me a stickler for precision ..
With EBC .. you keep the car running and adjust the boost as required ..
I'll agree with the protected though .. not many people can run 26psi with EBC and not throw a CEL ..
Old Mar 16, 2009 | 10:25 PM
Guru's Avatar
I prefer the AVCR in terms of a boost controller because it has both RPM AND gear based boost control for each of 5 gears. That being said, on a stock turbo car I agree that factory boost control works just fine. I see no reason for anyone to use an MBC. I have an FP Red and even with the stock weak actuator untouched it holds 22 PSI just fine with the stock boost control setup using ECUflash.
Old Mar 17, 2009 | 12:55 PM
EmperorX's Avatar
Can you keep the boost from tapering down just by tuning the ecu?
