Manual or Electric boost controller
Old Mar 14, 2009 | 07:07 PM
Evo a Mula's Avatar
I have been doing a lot or research and looking around and cant seem to find out what is better. what is the best all around a manual boost controller or and electric i was looking at the ams boost controller and the AEM electric boost controller and mabye this is a crazy dumb question but is there anyway to run both need to know because I need to buy one
Old Mar 14, 2009 | 07:39 PM
jmorris1027's Avatar
Ecuflash has full control over the stock bcs, why spend money on an aftermarket setup?
Old Mar 14, 2009 | 07:54 PM
Evo a Mula's Avatar
Because everyone that has good power to there cars has a boost controller or am i wrong?
Old Mar 14, 2009 | 08:02 PM
gizmotoy's Avatar
I believe the tuners have only recently gained real understanding of how the ECU-controlled boost leveling works. Early on in tuning the X, a MBC was simply easier.
It may still hold some advantages over the ECU setup, but I think more recently-tuned cars are more likely to control it electronically.
Old Mar 14, 2009 | 08:05 PM
I made 325hp and 345tq totally stock with just a jestr tune, on the stock bcs. Run whatever you want I don't care, but i'm saying from experience, a mbc will cause overboost in 5th and I hated that I couldn't give it too much gas when passing someone on the highway. If the stock bcs will allow you you to reach your target boost level...why run something else??
Old Mar 14, 2009 | 08:12 PM
Evo a Mula's Avatar
i didnt Know they had problems in 5th thats good to know thats why i made this thread. So even if I got an electric one like the AEm boost controller you think that would give the same or the same problems??? or would that be more safe
Old Mar 14, 2009 | 10:30 PM
Clark_Kent's Avatar
To manipulate and control boost more efficiently. Hopefully, a tuner will weigh in on the issue. Whether it be a boost pill, mbc or an alternate means of boost control anything at this point is better than the 100% stock boost control. The proof is in the data that has been presented many times over on this forum.
Old Mar 14, 2009 | 10:59 PM
Originally Posted by Clark_Kent
To manipulate and control boost more efficiently. .
elaborate.
Old Mar 15, 2009 | 09:01 AM
FLK's Avatar
FLK
Why use a MBC/EBC if you can get a protune and have the ECU control boost? Waste.
Old Mar 15, 2009 | 09:06 AM
+1. Atleast someone agrees. GST motorsports sells that pill which seems to work great when combined with a flash.
Don Nguyen's Avatar
As far as the original question goes, I personally use an electric boost controller
Old Mar 15, 2009 | 09:08 AM
gsr0801's Avatar
If your running stock turbo, run manuel boost controller. I recommend thr tru boost controller for high and big turbo cars.
Old Mar 15, 2009 | 09:25 AM
Everyone is going to have there preference, but no one will explain why. I ran a mbc for while and i was conatsntly adjusting. It seemed like it would never stay consistent. Also, in 5th, you couldn't give it very much gas for too long or else it would oveboost. I think a mbc has no place on a car with such complex electronics such a the evo x. If something oem can give you the boost you want with some simple tuning, then why would you not use it?
Old Mar 15, 2009 | 10:30 AM
ScorpionT's Avatar
If you want the best boost controller, get the Apexi AVC-R 2. If you dont have experience with tuning and dont need to adjust the boost, have it done with an ECU flash like Morris said. Most people dont need to and shouldnt mess with their boost levels, easy way to cause problems.
Old Mar 15, 2009 | 11:14 AM
MrBonus's Avatar
Agreed. Plus, I like to know that my boost control is tied into the ECU if the car were to ever enter limp mode.
