trans/diff broke
Old Mar 15, 2009 | 03:46 PM
gsr0801's Avatar
that sucks man. If sound like the rods at first though.
Old Mar 15, 2009 | 03:47 PM
casper980's Avatar
ouch, sorry to hear, keep us updated.
Old Mar 15, 2009 | 04:20 PM
wht95scort's Avatar
Deff a rod knock
Old Mar 15, 2009 | 04:25 PM
apagan01's Avatar
Originally Posted by Petey Turbo
Sounds like rod knock
same exact thing i was thining after listening to your vid,,, i am not very sure the car would drive ok with a blown TC, you would fell something at least when taking curves.
drain you oils and see which one comes out dirty,, with metal if any
Old Mar 15, 2009 | 04:30 PM
scottatyamaha's Avatar
Keep on filming it we might get to see that rod come through the block.
Old Mar 15, 2009 | 04:46 PM
4myX's Avatar
im still running stock cams
Originally Posted by kirkklau
4myX,
did you replace the valve springs when you do the cams? would that be the problem? does not sound like it is your tranny or diff.
kl
Old Mar 15, 2009 | 04:47 PM
bouncintiga's Avatar
not to beat the dead horse but yea definitely rod knock. my friends 4age motor did the same thing after oil starvation and severe overheating.
Old Mar 15, 2009 | 04:50 PM
4myX's Avatar
Ok, since ive been building motors and have been a mechanic for many years you can trust me it sounds like the engine but isnt. You can put your head in the engine area no noise, the transmission side is where its coming from and you can the feel the thud on the top front corner with your hand. Push the clutch in and the noise is gone. Heres your proof.
Old Mar 15, 2009 | 04:53 PM
Conor's Avatar
^^^ Outstanding rebuke, 4myX. It does sound like a trashed transfer case.. Just had one similar to that at work last week.
Where are you planning to source a new tranny or transfer case from? I forget what X ACDs go for, but the IX ACD is almost $4k at the dealer.. *facepalm*
Old Mar 15, 2009 | 04:55 PM
4myX's Avatar
Im going to have shepard do a stage 2 and replace whats broken
Old Mar 15, 2009 | 05:25 PM
EvoX2NR's Avatar
I don't understand how it could be a transfer case since it is only there when the engine is disengaged from the tranny. I think you **** a bearing or it is something to do with your clutch...
Old Mar 15, 2009 | 05:35 PM
PR_Mivec's Avatar
after that last video.. it might just be the clutch
Old Mar 15, 2009 | 05:44 PM
o7'silvermax's Avatar
how can a spun bearing not make noise when the clutch is pressed? it is obviously something in the transmission
Old Mar 15, 2009 | 05:45 PM
Gexxer's Avatar
4myx,
i had somethign extremely similar happen to me in my old GSX. What it turned out to be was one of the springs from the pressure plate came apart and lodges in such a fashion that it was "slapping" against the moving parts in the clutch area. sounded almost exactly like that. Fixed it with a new clutch pressure plate and flywheel. just my .02
Old Mar 15, 2009 | 05:55 PM
EvoX2NR's Avatar
I didn't say it was a spun bearing... I was talking about a throw out or pilot bearing. But I am leaning more towards one of the springs in the clutch failing.
