Heat wrap turbo? Good? Bad?
Old Mar 25, 2009 | 02:04 PM
EmperorX's Avatar
Hey is it a good idea to heat wrap my turbo? I know it makes it spool faster, but how much will it shorten the life of my turbo?
Old Mar 25, 2009 | 03:22 PM
Talon_66's Avatar
Bad.
Doesn't spool faster.
Old Mar 25, 2009 | 07:31 PM
EmperorX's Avatar
I found an article on this in import tuner they gained 10whp on a SR20
http://www.importtuner.com/tech/impp...ods/index.html
Old Mar 25, 2009 | 07:34 PM
chueu's Avatar
bad for its life i would think
Old Mar 25, 2009 | 08:52 PM
evoseller888's Avatar
not worth it for 10whp...
Old Mar 25, 2009 | 08:54 PM
NativeSS's Avatar
are we talking intake side or hot side?
Old Mar 26, 2009 | 04:10 PM
enter801's Avatar
Turbine side... it does allow them to spool faster, the exhaust gast is hotter and therefore thinner and can exit out quicker. You don't have to wrap it, you can get heat coating for it from SwainTech or HPC. Not to mention a coating helps for underhood temps. win-win...
Old Mar 26, 2009 | 04:56 PM
SiC's Avatar
SiC
As most of you know, the exhaust temp on the X is much higher than the previous models. This is partially due to bad heat dissipation from the turbo being in the back side of the engine bay. I'm sure Mitsubishi became aware of this so they made the hood vent and heat shields with a vent that is suppose to direct air flow to the turbo.
By wrapping the turbo, heat dissipation will be worse and it'll probably lead to turbo failure. So far, I know 2 stock turbos in Japan that failed from the exhaust temps being too high (both had stock exhausts). The shop was saying it was due to high exhaust temp caused by high back pressure from the stock exhaust system. By wrapping the turbo, you'll also be increasing your exhaust temp = increasing your chances of turbo failure.
Old Mar 26, 2009 | 05:05 PM
Protostar1's Avatar
There is also the issue that by wrapping the header, the actual metal will be heated to a greater degree and things like water can lead to cracking because of larger temperature swings.
Old Mar 26, 2009 | 06:04 PM
NativeSS's Avatar
just wrap the DP and call it a day.
Flanigen
23
Dec 10, 2009 05:47 AM
EvoJedi77
46
Feb 5, 2009 03:05 PM
kungfugirl
Lancer Aftermarket Forced Induction Tech
Sep 23, 2007 02:07 PM
BushBurninEvo
24
Oct 14, 2005 03:58 PM
RichJ
21
Feb 29, 2004 03:51 PM
