Lost boost when I went back to stock BOV?
Old Mar 29, 2009 | 06:45 PM
ScottSpeed21's Avatar
Pretty much.
Old Mar 29, 2009 | 06:49 PM
Evoryder's Avatar
most bov's work in both directions. I remember on my VW you could run the bov in either direction without issue. However...i don't think it will really work.
Old Mar 29, 2009 | 06:52 PM
Why wouldn't it work? When on the throttle, the boost pressure will hold it closed instead of push it open, and when off the throttle the intake manifold vacuum will open the valve like normal. Seems pretty straight forward to me
Old Mar 29, 2009 | 07:45 PM
gunzo's Avatar
.. I thought I was the only cheapo that do this sort of things
It works very well .. just beware of overboost
Old Mar 29, 2009 | 07:58 PM
Excalibur's Avatar
Can the hks be recirculated?
Old Mar 29, 2009 | 08:15 PM
jackygor's Avatar
Yes...if you have the Evo X hks kit already, dish out another 55 bucks to recur it.
Old Mar 29, 2009 | 08:16 PM
jackygor's Avatar
Logic ftw! I will try it right now and report back LOL
Old Mar 30, 2009 | 12:24 AM
ksig419's Avatar
my only question about the whole thing is that if you do this and your car has 20lbs of vacuum
and you have your boost set at 24 lbs then when you let off of the gas and the vacuum takes over wouldn't the BOV still be pressurized with 4 lbs of boost thus not opening the plunger? I am not saying that it would not work, I am just trying to figure the science of it out to make sure it is not hurting anything.
Old Mar 30, 2009 | 05:27 AM
gunzo's Avatar
The -ve pressure from the intake manifold will always pull the BOV open at high rpms high power.. regardless of how many psi you're boosting .. this -ve pressure is strong enough to overcome both the boost AND the BOV valvespring pressure ..
The BOV may have issues opening at light throttle low rpms .. that is your worry .. most people worry that this causes undue pressure buildup on the intake tract bouncing the pressure back to the compressor .. guess what .. when you go aftermarket BOV .. its the same deal ..
Old Mar 30, 2009 | 07:56 AM
ryanowarrior's Avatar
did you try it out? did it work??
Old Mar 30, 2009 | 03:51 PM
Excalibur's Avatar
What do I need to recirculate it? I don't have the bov currently.
Old Mar 30, 2009 | 08:24 PM
STi2EvoX's Avatar
How bad is the compressor surge at low rpms from doing this?
Old Apr 1, 2009 | 08:51 PM
RogueValley's Avatar
I still don't understand how the hell turning it backwards would make it work... Isn't the intent of the stock BOV to minimize surge? By turning it backwards and boosting then shutting the throttle, the air charge has NO WHERE to go other then back out through the compressor. Sure, when you're under vacuum the BOV may open, but then you have a vacuum leak. Or is there something I'm missing here?
Old Apr 2, 2009 | 09:57 AM
^ The stock BOV still works exactly the same as it did before, but now when the throttle is open, the boost pressure holds the valve closed instead of pushing it open. It will still vent the boost pressure when the throttle closes. The manifold vacuum doesn't hold the valve open all the time, only after you let off the throttle, and then the BOV's spring pushes and holds the valve closed. There are no vacuum leaks created anywhere.
It's the same way the HKS SSQV is setup
Old Apr 12, 2009 | 04:48 PM
t12ung's Avatar
This does NOT work ... I've tried it personally was having problems with this. I was told from Bryan@GST that it induces compressor surge as the bov will not open correctly.
