BAD BAD BAD Front CV axles
Old Apr 28, 2009 | 06:53 PM
Ferraritech's Avatar
well i agree on caliper shift causing a single or a small burst of clicks but it was a constant click when at full lock and it didn't matter whether it was just at start up or after i had driven all day. Namely i noticed it in the morning as well as when i was driving up my parking garage after my commute home from work. Its CV's. However J5isalive2 is correct that caliper shift is a similar sound.
Old Apr 28, 2009 | 07:13 PM
J5isalive2's Avatar
I just wanted to make that clear so we didn't have a bunch of people running to Mitsu claiming they have worn CV;s lol
Old Jun 5, 2009 | 11:23 PM
flyguycfi's Avatar
+1
I can see MMNA all of a sudden seeing like 100 people a day saying they have bad axels.
Old Jun 6, 2009 | 09:01 AM
stikllr13's Avatar
Yep mine is def doing this, I'm taking it to the dealership on monday. Did they gladly fix it under warranty or did you have to fight to get them to fix it.
Old Jun 6, 2009 | 01:25 PM
wht95scort's Avatar
Originally Posted by J5isalive2
people who say they hear this when backing up and then going forward...... its your brake rotors, when you brake when in reverse is shifts your rotors to the one side of the lug nuts which makes a POP....then again when you brake again in 1st gear and u get the same pop....don't confuse this pop with the CV joint
Ummmm if your rotors are moving when your backing up or going foward you may want to check your lug nuts. Thats not what your hearing. Your rotors should NEVER move like you stated. Sometimes you will here the pads shifting in the caliper brackets but this shouldnt be the case on an evo as there are no caliper brackets. I've heard of multiple guys having issues with the CV's and most were on MR's.
Old Mar 31, 2014 | 01:22 PM
iroc-evo's Avatar
Sorry to bump such a super old thread. but is THIS the noise that everyone is talking about??? If so, I think I'm in luck because I was just about to pull the transmission thinking it was a bad center diff. 2011 GSR with 72k miles. Thanks
Old Apr 3, 2014 | 07:36 AM
Sephiron's Avatar
Edit fail
Old Apr 3, 2014 | 07:41 AM
Sephiron's Avatar
Originally Posted by STi2EvoX
It's kind of a strange noise, almost like the sound that an aluminum bat makes when it hits a baseball, just no where near as loud. It seems to happen when backing out of my driveway when at full steering lock
I literally have this exact sound. I even said the same thing in my head. I had the entire front drive-train checked when I had some seals replaced but they couldn't find a single thing wrong. Mine tends to happen right at full clutch enguagement. Not "quite" as bad as the vid @iroc-evo posted
Old Apr 3, 2014 | 05:43 PM
AWDTerror's Avatar
Jack up the car and look at the axles and see if there is any grease slung about.
Old Apr 4, 2014 | 12:03 PM
iroc-evo's Avatar
No grease anywhere. Both transfer case and transaxle fluid looked fine (to me, but I must admit, I don't know exactly what I'm looking for).
I've already taken out the transaxle and and transfer case and I've arranged to have it sent to Jack's Transmissions.
I have a friend who is certain it's the center diff. But the guy at Jack's said it sounded like it might be front diff (in transfer case), so I'm sending them both units.
Also getting my front sway bar and timing chain done while I'm in there
Evojj25
15
Sep 25, 2017 07:56 AM
Ex'sAndOh's
Lancer Tranny/Drivetrain Tech
Sep 5, 2013 07:52 PM
bolc
10
Feb 6, 2012 04:43 AM
maxsideburn
Dec 7, 2010 09:10 AM
Davethewave
May 5, 2009 06:32 PM
