Boost pill - yes or no?
Old Apr 26, 2010 | 07:26 PM
4G63kevin's Avatar
Originally Posted by lowkey
Stage 1, pill in. Stage 2, pill out. Why are you unsure? It's very clear.
Sounds more clear now.
Old Apr 27, 2010 | 09:13 AM
ohitisethan's Avatar
i got a mr and i was told to get a boost pill because of the sst
Old Apr 27, 2010 | 10:45 AM
lowkey's Avatar
Registered User
With the Cobb AccessPort you REMOVE the pill for Stage 2.
Old Apr 27, 2010 | 11:12 AM
GST Motorsports's Avatar
People are confusing which pills are what.
The COBB instructions are for the solenoid side pill. Taking this out increases the boost all by itself but has some drawbacks.
The boost pill upgrade, is replacing the turbo side pill with a upgraded one that allows much more boost and fine tuning of the boost curve.
- Bryan
Old Apr 27, 2010 | 04:01 PM
403evo's Avatar
so why have pills at all? why not max boost all the time!!!!!
i ca understand manufactures using them as to maybe not put so much stress on engine? but why would you guys install a pill?
Old Apr 27, 2010 | 04:06 PM
Taking out the turbo side pill will drop boost to wastegate level boost.
Do a quick search on how a bleed type solenoid controlled boost system works to better understand it.
- Bryan
Old Apr 27, 2010 | 07:34 PM
VTC_XGSR's Avatar
Just out of curiousity, why not eliminate the "pill" system altogether and run a traditional boost controller? Does anybody know what the factory wastegate spring is rated for anyhow? After years of great control over boost levels via a few different EBC's (Profec, AVC-R) I just don't follow why the need for the whole "pill-in or pil-out" headache when you can simplify this via a small rotary knob or click of a button.
Old Apr 29, 2010 | 06:03 PM
The stock boost control is far superior to any EBC, and it comes with the car.
If you know what you are doing, there is no headache.
- Bryan
Old May 1, 2010 | 11:45 AM
VTC_XGSR's Avatar
- Bryan
Really now? Can this claim be substantiated? I ask because I've used Profec's and AVC-R's on both internally and externally gated units before with incredible accuracy so I'd have to ask what makes the OE unit not just superior but far superior?
Old May 1, 2010 | 11:48 AM
Robevo RS's Avatar
- Bryan
do you guys have a boost pill? /modified/
Old May 1, 2010 | 12:13 PM
Yes, really now.
The profec is basically a glorified MBC that is electronically controlled. The AVC-R is closer to the capabilities of the stock boost control system but also costs $400+. The HKS EVC is probably the best of all the EBC's but the more powerful features are a added cost option which can make the controller $600+
The stock boost control system on the Evo 10 has these features, and again, comes with the car:
1. per RPM (18 points of control) and per TPS % (9 points of control) boost control in 3D tables
2. Full error correction system with the same per RPM and per TPS % that intergrates with the same engine load the ECU sees to calculate fueling, etc. Which means it sees the same temp compensations as the other ECU controls.
3. Gear based boost control with a seperate 3D per RPM and per TPS % control
4. Boost limit cut control with fully tunable ms over/under delay
5. On the SST trans equipped Evo 10's, the stock boost control system is intergrated into the SST TCU and ECU controls.
Again, this is all available without another purchase
Add a 3 port boost solenoid for even more control ($100 or under added cost)
The stock system works well with internal and external gates.
- Bryan
Old May 1, 2010 | 12:49 PM
VTC_XGSR's Avatar
Well now, there's the answer I was looking for! Thanks, now I need to aquire the software to dive into it, this whole drop to 14psi at the top end is just killing me.
Old Aug 16, 2010 | 10:52 PM
dericchan1's Avatar
I am driving a MR. Have anyone try going stage 2 map without removing the boost pill? I wonder what would happen? I am guessing worst case scenario you are not getting the higher boost you want?
Thanks in advance
Old Sep 1, 2010 | 03:36 AM
bronto11588's Avatar
is the boost pill necessary after tune? if so is aftermarket made to different specs?
Old Dec 6, 2010 | 01:27 PM
MPACT's Avatar
Any more consensus on this? I just installed an AP Stg2 on my SE w/SST and am wondering if I should remove the boost pill or not.
