It was a sad day for me..
Old Apr 30, 2009 | 08:38 AM
monkeywinky's Avatar
man that stinks, hope you get your car in order soon.
Old Apr 30, 2009 | 08:50 AM
DG Motors's Avatar
Originally Posted by SiC
Go with a twin plate clutch, the pressure plate pressure is alot lighter than a heavy duty single clutch so it doesn't put much stress on the master/slave cylinder. I have yet heard of anyone having problems with hydrallic components on the EvoX when using a twin plate.
Happened with our evo x a few days ago. We are using an Exedy Twin HD
Old Apr 30, 2009 | 08:51 AM
DG Motors's Avatar
$100 dollars new from Mitsu. These clutch masters are junk.
Old Apr 30, 2009 | 08:52 AM
dragon831's Avatar
has anyone with the stock clutch had this problem?
Papi4baby's Avatar
Originally Posted by Western_man
All I can say. Is that the dealer is taking care of me in a good way. Thanks..
wm
Good to hear.
I haven't read about anyone with the stock setup having this issue. From what i understand the preassure plate is very strong and causes the plastic piston to crack.
Old Apr 30, 2009 | 11:16 AM
accrane's Avatar
so are you going to the Laguna event or no?
Old Apr 30, 2009 | 11:18 AM
mirebih's Avatar
already?? it seems like X has bigger clutch problem then VIII and IX..
Thats what i think from reading these forums.
Old Apr 30, 2009 | 01:14 PM
Western_man's Avatar
wasnt able to go..
Buttonwillow in June though..
wm
Old May 3, 2009 | 06:56 PM
evofan_08's Avatar
so wait, how can you tell the difference between needing a new clutch and needing a new master cylinder? Because when my clutch went, the pedal just dropped to the floor and never came back up but my mechanic never mentioned the master cylinder.
Old May 4, 2009 | 05:08 AM
gizmotoy's Avatar
A failing clutch slips. If the pedal doesn't return, it's the master cylinder. I can't say I've ever heard of a failed clutch sticking the pedal, but I could be wrong.
Old May 4, 2009 | 10:19 AM
storm_trooper's Avatar
are you really selling your clutch WM? if so i might be interested i hope you get everything worked out
Old May 4, 2009 | 12:24 PM
Evo a Mula's Avatar
is there a way to get a better master/slave cylinder or just stock??
Old May 4, 2009 | 12:38 PM
Evoryder's Avatar
great pic lol
Old May 4, 2009 | 01:40 PM
tomatoEVO's Avatar
sucks that even the exedy twins are causing this problem. wtf man?
Old May 4, 2009 | 03:54 PM
EvolvedVIII's Avatar
It seems that those who have blow out their slave cylinder have been using the HD clutches. Anyone having any issues with standard twin plates?
