CEL with downpipe and cat-delete
Old Apr 30, 2009 | 11:03 PM
Chuckdimpala's Avatar
I have a CEL with my MXP downpipe and cat-delete pipe....I'm assuming it is from the 2nd O2 sensor because the cat is gone and reading too much CO2??
Can I clear this for good or cheat it some way?
Is the motor running rich because of this?
Old May 1, 2009 | 01:43 AM
JoeyM3's Avatar
you need to get a mechanical o2 simulator
Old May 1, 2009 | 01:44 AM
Domolution's Avatar
^^ +1.....What he said.
Old May 1, 2009 | 08:50 AM
I kind of need a wired simulator the stock cat was cross threaded when I took the rear out it stripped completely out and the dealer wants $383.00 for a new O2 sensor--yeah right! So I had to JB weld the rear one back in and well its kind of stuck in the cat delete now
I called around and I guess no companies can make them anymore cause they got in trouble but someone has to have some laying around somewhere???
Old May 1, 2009 | 10:18 AM
JoeyM3's Avatar
lol that sucks
Old May 1, 2009 | 10:34 AM
rocknsnoboarder's Avatar
search for spark plug non fouler. If you can get one of these in there securely it will space your o2 sensor out further so it doesn't read as much of the exhaust gases which causes the computer to throw the code.
Old May 1, 2009 | 10:53 AM
tsbevo's Avatar
@JoeyM3: where can we buy one of these?
Old May 1, 2009 | 11:51 AM
ETS Michael's Avatar
This is how we get around it
You can also purchase a couple of anti foulers to pull the o2 sensor out of stream.
Old May 1, 2009 | 12:51 PM
Grendelrt's Avatar
You could of cut/cleaned the threads on the o2 sensor using a die. Mine was cross threaded too
Old May 3, 2009 | 07:55 AM
I tried that but it was so stripped it was even possible to go a size smaller even. I work in a machine shop believe me I know what a die is. So I'm trying the de-fouler method right now and doubling it up using two because I still got the CEL with only one of them. It took longer but it still popped up. Hopefully two does the job I'll let you guys know in a few days....
Old Jan 27, 2015 | 07:28 PM
felickz's Avatar
Thumbs down
Originally Posted by chuckdimpala
i tried that but it was so stripped it was even possible to go a size smaller even. I work in a machine shop believe me i know what a die is. so i'm trying the de-fouler method right now and doubling it up using two because i still got the cel with only one of them. It took longer but it still popped up. Hopefully two does the job i'll let you guys know in a few days....
op!!!!
MR.Evo.06
Northeast Region
May 15, 2011 06:04 PM
EvolNinja
Apr 8, 2008 12:38 PM
hondafan
Northeast Region
Jul 5, 2007 11:50 AM
LpBevoEvo
11
Jun 29, 2005 07:34 PM
binsquared
Apr 12, 2005 04:49 AM
