Best clutch for about 500HP
Old May 5, 2009 | 06:26 PM
Excalibur's Avatar
Originally Posted by TTP Engineering
We use it on our own car at 12.0@113mph+ full weight stock turbo.
It is good to 700whp. It is good enough for your 450whp.
As with any clutch, it will depend on your driving style and skill. It very well could last you years if you are a skilled driver.
Any downfalls to this clutch? PN to the one you're talking about? I'm looking to buy soon. I'm so nervous about buying an act clutch though.
Old May 5, 2009 | 06:34 PM
apex electric's Avatar
Try RPS twin plate carbon/carbon clutch rated 700'lbs
Old May 5, 2009 | 06:40 PM
TTP Engineering's Avatar
There are really not any downfalls. The pedal effort is light. The friction coefficient is greater which is why a stiff left leg pressure plate is not required to hold 650+tq.
It is a TTP proprietary clutch.
Old May 5, 2009 | 06:42 PM
The RPS has a light pedal and is street able, except don't side step the clutch pedal with the carbon twin, it won't slip. It will spin the tires or leave broken transmission pieces behind you!
Old May 5, 2009 | 08:07 PM
MIGHTYMOUSE1's Avatar
my opinion for clutch is an spec twin
Old May 6, 2009 | 03:42 AM
Excalibur's Avatar
It seems like there are so many opinions regarding clutches. Don't know which to go with.
Old May 6, 2009 | 04:04 AM
Ameen77's Avatar
Dude go for the HKS twin plate clutch. The kit also comes with a lightweight flywheel. they also have a triple plate clutch. check their website. and trust me you can't go wrong with HKS
Old May 6, 2009 | 06:32 AM
ScottSpeed21's Avatar
It comes down to what you're mostly using the car for. My car is daily driven so to me, street driveability comes first and foremost. The last thing I want is a clutch with a heavy pedal or that can't easily be slipped while driving in traffic.
I'm liking the TTP spec ACT clutch, and that's what I'll probably go with.
Old May 6, 2009 | 08:20 AM
miniend's Avatar
non for the X
Old May 6, 2009 | 08:21 AM
Bom's Evo's Avatar
Originally Posted by MarkM
I went for Cusco, it's exactly the same clutch as the Exedy Twin plate (Exedy make them), great feel, only very slightly heavier than stock, quiet for a twin. I'd personally stay away from ACT though
Very good clutch. Lasted 60k miles. 400lbft of torque. Maybe 4 events a year...
Old May 6, 2009 | 08:23 AM
A heavy pedal effort will break the master cylinder, leaving you with NO CLUTCH AT ALL as you will not be able to depress it and you'll rack up a few hundred + in repairs at the dealer. A dealer in which you will have to TOW the car to since the clutch will be unable to be depressed, rendering the car undriveable.
Old May 11, 2009 | 10:05 AM
Boostd4's Avatar
It sounds like the ACT HD pressure plate with a street disc is probably a good option for a street driven car with the occasional track day thrown in. Seems like this setup is least likely to split the master cylinder...anyone have insight on this?
Old May 12, 2009 | 09:58 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
yeah my thoughts on clutches ( my silver evo 8 is sponsered by exedy and i run their triples ) but i love them and was thinking of using their twin in my X OR maybe even trying out the new spec twins. we put one in a 350z turbo and its been great for him. Other inexpensive option is the stage 2 singe disc exedy.
Old May 15, 2009 | 12:31 AM
fusionofideas's Avatar
go with the best and get the Exedy Multiplate. If your going to spend the money on the labor might as well do it right the first time. The X is not a fun clutch replacement so you wont want to do it again and again. I have been running the Exedy Multiplate for about 3k miles and have been very happy on the street and track
Old May 15, 2009 | 08:34 AM
EXEDY multiplate has blown master cylinders. If you don't want to be stranded with a few hundred in repairs only to break it over and over again, stick with an HD singledisc with light pedal effort.
