1/8 tap on intake manifold
Old May 7, 2009 | 01:49 PM
rogue's Avatar
Is there a place to add a 1/8 NPT size MAF sensor on the intake manifold?
Old May 7, 2009 | 03:37 PM
Clipse3GT's Avatar
Electronic Boost gauge sensor?
I sure you can use a split T connector from one of the fittings already present in the manifold.
Old May 7, 2009 | 03:53 PM
rogue's Avatar
Yes, I know that part. I want to screw in the MAP senseor sort of like what I have done with and oil pressure reader on my old evo 9. I already have the T from the blow off valve. =)
Old May 7, 2009 | 04:42 PM
WarmAndSCSI's Avatar
It's a MAP sensor, not MAF.
You can always make a small external housing for it using pipe fittings, including a 1/8 or 1/4 in barb you can hook up to a T-ed vacuum/boost line.
Old May 7, 2009 | 05:25 PM
rogue's Avatar
Yea, I mistyped MAP...Brain fart.
I already have my MAP sensor T-ed off, so that was not my question. I also know that I can weld a bung onto my intercooler pipe and connect the MAP sensor.
What I want to know: Is there a provision on the intake manifold itself that has a screw already in place that can be removed, that is 1/8 in size that I can use to mount the MAP sensor there.
I referenced the oil gully on the 4G63, because I was able to directly hook up a pressure sensor there for my oil pressure gauge by removing the hex screw on the head.
Maybe there is no provision, maybe there is, I am just checking to see if there is or if anyone has on the 4B11.
side note - WarmAndSCSI, did you get my PM?
Old May 7, 2009 | 05:38 PM
Clipse3GT's Avatar
Everything you will ever need or want.
Old May 7, 2009 | 05:50 PM
rogue's Avatar
Nope.
Looking for a provision on the Intake Manifold that is already taped from the factory and already has a hex bolt in it to hook up my map sensor directly.
Old May 7, 2009 | 05:58 PM
rogue's Avatar
Looks like this guy has already checked and did not find any: http://www.evoxforums.com/forums/showthread.php?t=12554
Old May 7, 2009 | 06:00 PM
I don't think there is one, looking at the FSM. The IAT sensor does have a tapped hole, though. Obviously you can't just get rid of it. Hmm, well, you can always tap your own. There are many thick areas on the intake that would work well.
Old May 7, 2009 | 06:03 PM
rogue's Avatar
Nice, I was also looking at the FSM. I was really just looking to remove possible ares of leakage, I guess for now I will keep it like this until I have to take of the manifold to have it ported someday.
Thanks for the responses.
daimon
evo8vz
Dec 16, 2016 08:27 AM
Jaysaevo8
Apr 5, 2016 01:06 PM
Philly
Aug 22, 2013 05:25 AM
wasabisnooter
Oct 14, 2010 02:42 AM
EmeryatSTM
Jan 19, 2010 04:11 PM
