Accelerated onto expressway then extreme misfiring...
Old May 10, 2009 | 07:54 PM
candymanjl's Avatar
Originally Posted by junction
I didn't drop any of the plugs. I saw the lack of gap immediately when I pulled it out of the cylinder. It was gapped from the factory. Pretty sure these are factory plugs unless AMS swapped them with the tune. That is possible I suppose. Either way something happened that caused this. Yeah the drop in may have changed the boost a bit. Its possible.
like another poster said they probably would have told you if they changed the plugs, unless they're kind enough to hand out free $40 sets of plugs
well that lack of gap will surely give you ignition issues, just look at how black that plug is and you can tell it's running pig rich in that cylinder. I'd get a new set of plugs gapped to the factory spec and see what that does.
Old May 11, 2009 | 07:42 AM
Chris@AMS's Avatar
I really don't think its possible to close a plug gap with detonation... In fact, I'll dare to say its impossible...
However, typically when you see ground straps smashed into electrodes, it means that there is a foreign object in the cylinder! This is not a good thing obviously. I have only seen this happen a couple of times. Sometimes you get lucky and the object moves through the cylinder and doesn't do any real big damage. I have also see the opposite where it totally destroys the piston and the head!
Since the car still runs, the damage can't be that bad. Sounds like he is coming in so we can just stick the bore-o-scope in it and see whats up!
Old May 11, 2009 | 11:06 AM
Mad_SB's Avatar
Mine still ran with about 1/3 of the top of a piston cracked off
I agree that det won't close a gap up like that, when my piston let go, the electrode was kicked to the side and pushed towards the threads.
Sucks for the OP, but it's more likely to be debris in the chamber.
Old May 11, 2009 | 11:41 AM
MrEVO313's Avatar
hope everything works out gl
Old May 11, 2009 | 02:24 PM
TTP Engineering's Avatar
You are correct about the foreign debris. He broke the ring lands in that cylinder like all of the other Evo X's. We have been warning people about this for some time now. FYI, detonation can bridge grounding straps but that is not what happened in this case.
The ring ends collide and take a piece of the piston with it.
The piston schrapnel works its way through the turbine blades degrading the turbo on its way out.
One of your pistons is likely damaged at the least, the turbine blades are likely chewed up and your cylinder compression in the damaged cylinder or cylinders will continue to degrade over time before you will need to rebuild the engine.
To Chris's defense, probably is NOT detonation related, however increasing the performance of the engine can lead to this top ring failure.
Old May 11, 2009 | 02:28 PM
Debris likely caused by the failure of the piston ring and ring land contacting the spark plug grounding strap.
We have seen this many times already.
Old May 11, 2009 | 03:00 PM
Chris@AMS's Avatar
Originally Posted by WarmAndSCSI
You really work at AMS?
I've closed plug gaps many times before because of detonation. Shall I start posting photos of the victim plugs? I've got probably a dozen of them.
I'm not sure why you are being so abrasive about this. I'm not sure what pictures of spark plugs are going to prove either. Personally, I don't see how its possible for detonation to close a plug gap unless there were some really out of hand conditions in the cylinder that would likely cause other failures at the same time.
Maybe I'm just 'too conservative' of a tuner to ever have noticed this phenomenon.
TTP: Your concern has been noted in a couple of threads now. I will be sure to let you know if we ever have a single problem relating to this.
Old May 11, 2009 | 04:48 PM
GST Motorsports's Avatar
Really? Hmm I guess I didn't get this memo yet.
-Bryan
Old May 11, 2009 | 05:04 PM
mantella's Avatar
I have done this to a civic I own and to a beetle but the beetle motor died at that time. On the civic I had gotten bad gas and the water for somereason did not want to compress as well as fuel. I do see it on gm 3.8 motors about once every 6 months from hydrolocking caused by bad intakes which is not the problem here. I would have to go with there is really no good guess untill the boroscope checks it. If all good there I would ponder if it was possible that the injector stuck open and flooded the cylinder or bad gas.
Old May 11, 2009 | 05:13 PM
mrfred's Avatar
I've read lots of stories of head lift, bent rods, and destroyed main bearings, but this is the first time of heard of a ground strap getting hammered by the pressure spike of a detonation event. Will be interesting to see if a piece of the guy's piston is missing.
Old May 11, 2009 | 05:14 PM
-Bryan
The east coast is 3 hours ahead of the west coast. Its not surprising that the west coast is trailing behind in the information stream.
Old May 11, 2009 | 05:18 PM
Interestingly enough we pulled another top ring out of an Evo X turbo today. We have it saved under glass for display in the showroom.
Once again the turbine blades are chewed up and out of balance.
Hey at least the turbo got a free clipping to increase exhaust flow.
This will be another core for an FPRed for Evo X as they replace the turbine shaft with the larger one anyway in the build.
mrfred's Avatar
Not bad.
Old May 11, 2009 | 05:19 PM
lol, I have to say, that gave me a good chuckle.
- Bryan
Old May 11, 2009 | 05:23 PM
-Bryan
https://www.evolutionm.net/forums/ev...k-block-4.html
https://www.evolutionm.net/forums/7027740-post50.html
https://www.evolutionm.net/forums/7028639-post56.html
