Clutch & Flywheel - Check Light
Hello everybody..
I have Mitshubishi Evo X - GSR - Manual 5 Speed Transmission - CZ4A - 4B11 - 2007 -
My clutch has burned - Recently I have changed my clutch lining with a New ACT ME1-HDSS & ACT StreetLite Flywheel for Mitsubishi EVO X GSR - 5 Speed Manual Transmission.
The car runs smoothly without any problem. But after finished installed the Clutch & Flywheel with it came up with these 2 or more Type of Check Light.
1. Yellow indicator 4-wheel logo (Service Required).
2. Yellow ASC Logo (Something like the Car Skidding Logo)
3. The ASC button (On & Off is not Working) - But the ASC Indicator in ODO Meter is OFF.
4. S-AWC Indicator is there but Not working like Always, I mean the S-AWC Meter Indicator Running up down while Driving.
5. ACD Buttons like Tarmac , Gravel , Snow not working.
6. Sometimes The RMP Meter playing automatically from 850rpm (normal) to 400rpm -Up & down, up & down for few second - While the car is in IDLE MODE - Without anyone touch it.
I dont know why is that. But is it normal after you changed to a new Clutch lining, Is there any check-light came up? - The car ECU/Computer need to be reset/Flash?
Or some of the symtoms? Any of you have experieced of these problem -
Pls let me know guys . Really really need your best help here.
Thank you & Have a good day.
God bless you all..
Azreen Khan
God bless you all..
Azreen Khan
Figure this one out yet? Wonder if not disconnecting the battery during installcould cause this some warning lights. Sure you tried this, but maybe a simple disconnecting the battery, waiting 15 mins and reconnecting...maybe ensuring all of the fluids were topped off correctly.
Hello everybody..
God bless you all..
Azreen Khan
God bless you all..
Azreen Khan
Thank for the advices. But I wonder how to bleed out the air.
I mean manually step by step. My technian told me there is 2 place of the bleeding screw/plug of the acd/ayc system of the evo x.
Have anyone heard of the Evo X ECU will gone to [Safe.mode] once it is not properly install the clutch or the AYC/ACD systems?
Safe.MODE means we cannot fix the car
1. ECU
2. Even we already filled the ACD/AYC fluid.
The check light is still there. We have to get the original MT2 or MT 3 - computer to
fix the evo X.
The biggest problem is in my place, There is no Mitshubishi Evo X MT2 or MT3.
I actually imported this car directly from Japan. Btw. I am from MALAYSIA.
The Mitshubishi dealer here only have for Evo 8 - 9 system.
1. ECU
fix the evo X.
IMPORTIMAGE
109
Oct 12, 2010 11:12 AM
Sam@DriveLine
EvoX 'For Sale' Electronics / Lighting / Audio
121
Jan 8, 2009 02:20 PM
IMPORTIMAGE
959
Oct 17, 2008 02:40 PM
IMPORTIMAGE
142
Aug 24, 2006 09:40 AM
