New turbo setup
Old May 14, 2009 | 03:30 PM
TurbotrixRacing's Avatar
Originally Posted by J5isalive2
I don't forsee a melting issue, i forsee a cracked weld, or a loose manifold after ripping out the manifold studs from the block.
Is it a good idea to be bracing the turbo to a solid surface? I forsee bracing it to the solid surface will put unneeded stress on the manifold when the engine shifts under heavy acceleration.
Perhaps this brace is temporary as you progress through the build.
Everything looks great other than the brace!
That brace is just there to hold the turbo in place so we could make the manifold. The actual turbo support brace will be bolted to the transmission.
Keith
Old May 15, 2009 | 08:08 PM
boostzealot's Avatar
damn im soooo glad to see this. i was just talking with my best friend the other day about someone doing this soon and bam you guys hook it up. what numbers are you looking for? (spool times, peak power, peak torque, egt's, and so on) what turbo will be used for the preliminary testing, and are you planning on selling this manifold separate to create a wide span of turbos to install by the customers preference? sorry to be so inquisitive but im just excited.
edit: looks like a GT3582 on there now, i guess thats what you guys are going for? if so will you build one for a 37R?
Old May 15, 2009 | 08:54 PM
trickytrick's Avatar
my friend is running a manifold the same way on his rsx. looks sick. cant wait for the results.
Old May 15, 2009 | 09:24 PM
Bighec's Avatar
Sounds like you guys have it all figured out!!! Definitely can not wait to see the finished product!
Old May 16, 2009 | 12:56 AM
weap0n's Avatar
Very cool. Very different.
+1 for more progress as it happens.
Old May 18, 2009 | 03:48 AM
kjewer1's Avatar
The brace is obviously temporary. It's a real ***** to tig weld while holding up a 30 lb turbo with your porksword. I just built a new setup for a T6 that weighs 50 lbs, what a ***** that is to work with.
I've also installed turbos on K motors and while it looks scary, nothing melts if you protect everything properly even when daily driven hard.
Looks good Keith, post pics when it's finished.
Old May 18, 2009 | 12:16 PM
slo4g63's Avatar
Nice work, please keep us updated on the progress and final numbers....
TurbotrixRacing
Evo X Dyno Results
29
May 3, 2009 03:38 PM
TurbotrixRacing
Turbotrix Racing - Edison, NJ
Jan 25, 2009 08:53 PM
TurbotrixRacing
Jan 19, 2009 09:03 AM
TurbotrixRacing
17
Nov 17, 2008 09:27 PM
TurbotrixRacing
Jul 7, 2008 02:21 PM
