Changed my tranny fluid today....opps?
Got up there and drained the fluid out. I jacked the car up on the passenger side and then jacked up the rear passenger side higher to make sure i get all the fluid out. I put the drain plug back in and tigthen it down. There was some shavings on the plugs. My car has just about 900 miles on it.
I put the car back on all 4 tires, I'm in my drive way and it is pretty level. I go to fill it and I put 2 quarts in. Thinking .. It should take a little over half of the 3rd bottle. Well I'm waiting for the fluid to start coming out of the fill hole. After I poured over half the bottle in there, I back the hose out and the fluid starts to come out. So I let it drain out thinking I've filled it to much. The 3rd bottle has 32 oz, I poured all put 9oz in there. 32-9 = 21oz. so 21 oz of the 3rd bottle was poured in there. I let it drain out until it became a fine little stream. Then I put the drain plug back in. I didnt wait for it go to drop drop drop. ya know? took it for a test drive, 2nd was harder to get in to, but it wasnt completely warmed up yet (tranny wise, motor about to) up and down the road I went and it seems to get smoother as it got warmer. just paranoid about having to go to the deal bc of 2nd gear. The car was build in feb/march of 2008
Did I **** up on anything?
It sounds like you did a primo job - as long as you used the right fluids which I'm sure you did. Often, when you drain the tranny, I think it takes a while for the new fluid to penetrate back into all the rings on the synchros and so you'll have some stiff shifts until it works itself in. It's highly unlikely that a slight variance in the fluid level will hurt you.
+1 The MTG is 75W-90 vs. 75W-80 for the OEM DiaQueen. I use MTG as well and yes the 1-2 upshift when the fluid is cold will be a little tight. Shifts should loosen up after a few minutes of driving.
man i tell you what evom members are talking about AMSOIL left and right, the result we have gotten on our testing has been shown in the community.
nothing better than real world testing and customers coming back and saying this has given me results.
TO EVERYONE WHO SUPPORTS AMSOIL THANKS, AND IF YOU NEED ANY HELP PLEASE LET ME KNOW
chaotichoax
32
Feb 11, 2020 09:00 PM
Evoryder
Apr 29, 2019 10:09 AM
StreetThisEvo
22
Jul 23, 2012 03:48 AM
