short throw shifter recommendation
Old Jun 24, 2009 | 12:19 PM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Works + AMS Bushings (base and under hood)
Old Jun 24, 2009 | 12:20 PM
JoeyM3's Avatar
on the twm is the overall height the same? seems a bit tall in the pics
Old Jun 24, 2009 | 12:32 PM
blk-majik's Avatar
Any word on the MODE/Cobb short shifter?
Old Jun 24, 2009 | 01:05 PM
flyguycfi's Avatar
I really like my TWM short shifter + base bushings!
Here's a pic from install. (have to do this for any of them)
Old Jun 24, 2009 | 01:30 PM
DarwinX's Avatar
The TWM short shifter is 1.25" shorter than stock.
Stock shifter is the silver one on the right in my picture.
Old Jun 24, 2009 | 01:39 PM
JoeyM3's Avatar
probably the knob makes it look bigger, i have the one without the neck in my dad's civic si
Old Jun 24, 2009 | 01:45 PM
blk-majik's Avatar
And from the Works site: http://www.worksevo.com/store/produc...roducts_id=540
The installation does NOT require any cutting/trimming of the factory carrier housing.
So Works SS owners.... how was the install?
Old Jun 24, 2009 | 01:55 PM
sylnraul_evox's Avatar
in my opinion....this is the way to go: tmw short shifter+works urethane bushings+tmw weighted shift knob....that's what i'm getting anyway. From what I understand the urethane bushings are much nice on other parts/dont place any added stress on other parts. And if you're looking to improve on your shifting feel, then I would switch over to AMSOIL tranny oil also...
Old Jun 24, 2009 | 03:01 PM
ice1874193's Avatar
whats the advantage of the short throw over the stocker?
Old Jun 24, 2009 | 03:08 PM
Iceman5's Avatar
the reason why I said TWM.. cuz I tried it on my friends car and feels awsome... The throw is much shorter and it shifts pretty smooth... I've ordered mine and can't wait to put it on my car...
Old Jun 24, 2009 | 04:43 PM
smoothevo's Avatar
The main goal is to get shorter shifts since the X has about 1ft in between every gear - at least it feels like that to me. Shorter shifts and you can keep the RPM's up higher between shifts as well.
Old Jun 24, 2009 | 06:55 PM
JoeyM3's Avatar
you just have to grind off a clip, which is probably what he is doing. other than that the install is pretty easy, it took me a while because i did the steering wheel audio controls at the sametime
Old Jun 24, 2009 | 07:00 PM
flyguycfi's Avatar
Yea I was just cutting the clip that holds those 2 pins in. It's either that or pry it off with a flathead screwdriver, but that was a lot more difficult than just cutting it off.
Old Jun 24, 2009 | 07:04 PM
evolvedx's Avatar
Hold up, you've been mislead here. The guy who posted the pic w/ the dremal is not cutting/trimming the factory carrier housing, he's cutting off the clips that hold the retention pins in place. You have the remove these clips to access the shifter - period. You can pound them off w/ a hammer/chisel, but cutting them off is by far the quickest and easiest way.
I have the TWM and the base bushings, and I'm very satisfied.
Old Jun 24, 2009 | 07:33 PM
slo4g63's Avatar
If you look at what I call the pivot point, it is higher than on the stock one. Plus just a tad shorter in overall height..... Both combined would make a "shorter throw". Were you thinking of the entire shifter just being really short?
