Catch Can Setup
Old Jul 14, 2009 | 01:28 PM
flyguycfi's Avatar
Catch Can Setup
So after having oil spew all over my engine bay I have decided to get an oil catch can so my PCV line from the block to intake wont be kinked anymore.
I am going to get the can from AMS, along with the AN fittings and line. Does a line from the block to the can, then the can to the intake sound about right? Inline steup is best right?
I'm just a little confused with where I need fittings and whatnot. It's my first time using AN fittings/line. Maybe I'll just use standard ruber line. IDK yet. Thanks!
Old Jul 15, 2009 | 12:10 AM
flyguycfi's Avatar
Any ideas guys?
I would really like input form anyone who has a catch can setup at all.
Old Jul 15, 2009 | 10:29 AM
alex3dworld's Avatar
I did a couple of test with a Cusco oil can a few months ago. Nothing! I don't think we need such equipment unless you run racing pistons (I suppose). The amount of oil collected was insignificant. I had V8's before and the difference is huge. You can collect 2 or 3 full spoons of burn oil a week. a month after install it in the evo I collect half spoon/ clean oil.
do you have some pictures to share about the ..."oil spew all over the engine bay"....?
make a search in the evo x forums about: oil catch can
there is more than a couple of trheads about it
Old Jul 15, 2009 | 11:35 AM
Nammy's Avatar
I went with the PERRIN catch can, and I have it connected inline just as you described above. It has been on the car for more than 4 months now and it is still pretty much clean. There was oil residue in the stock line when I took it off, so a minuscule amount of oil does come through. Is the catch can necessary? No, but it is a cleaner way to run the motor.
Here is a picture of how I've got mine installed:
Old Jul 15, 2009 | 07:45 PM
ChinoBling's Avatar
Looks good. Very out of the way. Do you think it would still fit in the same spot if you had the BOV in the factory position?
How/where did you mount the catch can if you don't mind my asking?
Old Jul 16, 2009 | 08:58 AM
Nammy's Avatar
I don't think the PERRIN catch can would fit there with the BOV in the stock position. The lines connect to the top of the PERRIN catch can, and I had to bend that bracket a good bit to get it to clear the strut bar. If you were using a different catch can where the lines connected to the sides, for example, it would probably still work.
Biggy VIII
Aug 9, 2016 03:06 PM
EvoIX89
17
Sep 22, 2015 07:11 AM
mrm95
Oct 16, 2014 06:39 PM
Titish
18
Sep 6, 2014 09:02 PM
DormantBeast
Jun 15, 2012 12:21 PM
