Serpentine Belt Adjustment HELP!
Old Aug 16, 2009 | 02:41 PM
jdm ctr ek's Avatar
Hey Guys,
I'm in process of installing the AMS A/C delete on a EVO X GSR. I need to adjust the tension on the Serpentine/Accy belt. Anyone know how I would be able to do so?
Thanks..
Old Aug 16, 2009 | 06:46 PM
02-Lancer-Es's Avatar
Doesn't it adjust its self ................
Old Aug 16, 2009 | 06:47 PM
Farred's Avatar
i thought we had an auto tensioner.
Old Aug 16, 2009 | 06:58 PM
Talon_66's Avatar
This thread is full of fail
Old Aug 16, 2009 | 09:35 PM
jcpahman77's Avatar
I've been helping a friend with his X, that's why I made an account. We recently replaced the serp belt and it is indeed auto-tensioned. We did have some trouble with the belt routing though since the old belt had snapped. Is there a good resource for this kind of info for this car?
Old Aug 17, 2009 | 04:15 AM
JakeTheVIII's Avatar
Make sure you have the correct (shorter) belt. It will tension automatically
Old Aug 17, 2009 | 05:28 AM
GEVO 8's Avatar
Im pretty sure the AMS a/c delete kit uses the standard length belt. Maybe you should call them to be sure.
Old Aug 17, 2009 | 05:35 AM
You're right. My bad.
The AMS EVO X A/C Delete Kit allows for removal of the compressor, lines and condenser for a weight savings of 20 lbs. The black anodized billet aluminum bracket with CNC’d AMS logo is lightweight and durable for a long life. This kit is easy to install and utilizes your factory serpentine belt for simplicity.
So it should just tension up like normal, as it was stock.
Old Aug 19, 2009 | 07:40 PM
jdm ctr ek's Avatar
To the ones that had useful information Thanks! but one other question.. How do you release the tension on the belt, so I can unbolt the a/c compressor?
And to the ones with the stupid comments... I can tell you send your car to a shop and pay them to have your work done..
Old Aug 19, 2009 | 08:20 PM
DannyK24's Avatar
most vehicle with auto tensioners should have a dedicated bolt on the tension arm to have a wrench attached so you can push down and release tension, allowing removal of the belt.
Old Aug 20, 2009 | 04:33 AM
This.
On the 8/9, it's a square hole that accepts a 1/4 drive . You pull it towards you to de-tension it.
sammiek513
Lancer Engine Management / Tuning Forums
Nov 10, 2014 04:55 PM
pdizzle
21
May 20, 2014 02:20 AM
jtcarstens
Jan 8, 2014 06:49 AM
PersianEVO
36
Jan 2, 2014 01:26 PM
Alterna
12
Sep 10, 2012 02:32 PM
