Evo X Big Bore 64 mm Throttle Body
Old Aug 20, 2009 | 08:56 PM
Hiboost's Avatar
I would be interested in a core charge setup as well, even if it cost an extra $50 for the process as my car is also my daily driver at the moment. Sure I can rent a car for a few days but where can you rent a 500 hp car these days... boost withdrawal symptoms set in after 8 hrs for me!
Old Aug 21, 2009 | 05:20 AM
Boomba Racing's Avatar
Originally Posted by fmax420
Does this cause the idle to change at all? I have had bad luck with ported throttle bodies in the past. I will probably wait for dyno results before purchasing this item.
Idle is like stock TB no difference.
Old Aug 21, 2009 | 02:53 PM
kozmic27's Avatar
Based on the turn time stated on their web site, putting a core on a credit card, and having it reversed before the bill comes should be easy as pie. I am going to do this at the same time as my intake manifold. Hopefully before Halloween.
Old Aug 21, 2009 | 03:00 PM
EndlessRed's Avatar
gtfo.
Old Aug 21, 2009 | 07:40 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
secksy if you guys need some help testing or anything let me know hehe
Old Aug 21, 2009 | 09:00 PM
flyguycfi's Avatar
Originally Posted by endGameXIII
gtfo.
What's wrong with that???
Companies do that all the time!
Old Aug 21, 2009 | 10:27 PM
LVSBB6's Avatar
It costs just as much as the JUN big bore throttle body, but 1mm less in size.
http://www.junauto.co.jp/products/in...le/index.html?
Old Aug 21, 2009 | 11:43 PM
VRSF Tiago's Avatar
And your point is?
TrackAttack78's Avatar
You still have to send in your TB to jun since their us office closed you would have to send it to japan. I don't think you will get it in a week. Good luck with that one. Boomba is a vendor that you can contact directly. Good luck talking to someone at jun
Old Aug 21, 2009 | 11:52 PM
EndlessRed's Avatar
uh, and people here complain about getting scammed, when the consumer tries to scam the companies?
actually if you look at core charge included, it's about the same, assuming neither does core exchanges. but you're right about the contact bit - good luck getting someone there to answer you.
Old Aug 22, 2009 | 12:45 AM
VRSF Tiago's Avatar
I think he meant he'd get his credit refunded after he provided his original TB....
Old Aug 22, 2009 | 01:24 AM
tonyboy's Avatar
Core charge would be around 900 since that is the cost of a new tb it's less to rent a car for a week and get the mod done
damn those etb! it costs a lot...
OP, how much to actually port match the tb and im? TIA
Old Aug 22, 2009 | 01:57 AM
EndlessRed's Avatar
oh i get it now the whole thing about having it reversed made it sound like the guy was gonna file a fraudulent charge or something to that end. but yeah that and/or whatever that entails a deposit/refund.
Old Aug 22, 2009 | 08:19 AM
It is cheaper and we are in the US. There is the reason that we went to 64mm. Boring TB to 65 mm leaves wall thickness less then 0.02 in (0.5 mm) in some places. It makes it very weak, so we decided to stick with 64mm and not compromise casting strength.
Old Aug 22, 2009 | 08:22 AM
LVSBB6's Avatar
The Jun TB cross section is 3% bigger than this one, for the same price it is a better buy.
And your point is?
