Evo X Big Bore 64 mm Throttle Body
Old Sep 4, 2009 | 09:51 AM
  #46
Evo a Mula's Avatar
10whp sounds good to me im happy i just got mine in the mail..thanks for the tee boomba ftw
Old Sep 4, 2009 | 10:05 AM
  #47
Enjoitk's Avatar
loss of tq, but not much
Old Sep 4, 2009 | 11:08 AM
  #48
LVSBB6's Avatar
Not bad, but I wonder what the gains are without the port match to the intake manifold.
Old Sep 5, 2009 | 12:43 AM
  #49
TrackAttack78's Avatar
I'm sure u will see greater numbers with bigger turbo and dyno tune still it's a good start
Old Sep 23, 2009 | 06:43 AM
  #50
Boomba Racing's Avatar
Bump!
Old Oct 7, 2009 | 02:48 PM
  #51
Freebs's Avatar
I know this thread is a few weeks old now but I didnt want to make another post on this...
Maybe Boomba Racing will be able to answer this but how much of a difference would it make if I did the following;
- OEM Intake Manifold porting (to try and match the 64mm throttle body)
- OEM Turbo Porting
- OEM Turbo Manifold porting
- Boomba 64mm Throttle body
- 2.5" hard charge pipes (to get rid of the balloon pipes)
- Bigger intercooler
- Cold Air intake
basically making everything but the head flow a bit better and get rid of the balloon charge pipes. Reason I am asking is because I am looking to keep every thing "stock" looking and too help me reach my goal of 300awhp on a mustang dyno. So I am wondering if Boomba has done testing on any other parts by porting them or if any one has gone this route
Old Oct 7, 2009 | 02:53 PM
  #52
LVSBB6's Avatar
Just so everyone know, this is not a simple plug and go mod. You need a re-tune or else the ecu will dump a limp mode on you.
Old Oct 7, 2009 | 03:04 PM
  #53
Freebs's Avatar
Is this for sure? Or are you just assuming? Not trying to start a fight or be a smart ***... Just I was told this about adding an intake to my MR. People said my transmission would be shifting erratically, getting into limp mode as well as I would be getting dangerously lean… And after throwing the intake on none of this happened and I wasn’t running anywhere near lean conditions.
So my point being is have you tried this throttle body or is it just something you are going on from past experience? because I have two other turbo cars (gnx and TT Z06) and both showed a nice increase when going to a larger TB..
Old Oct 7, 2009 | 03:28 PM
  #54
EvoX_SA's Avatar
he has the 65mm JUN Throttle body and is currently working out his tune to accommodate the new TB
Old Oct 7, 2009 | 04:54 PM
  #55
Freebs's Avatar
So he had a custom tune on the car before he put the JUN TB on? That could explain why because when I run the regular Cobb AP stage 1 tune with my intake I get a code... but when I run the AMS Stage 1 tune or no tune at all (stock mode) I don’t get a code at all. So what I am saying is its most likely playing with the custom tune and would work fine with no tune as Boomba is stating
Old Oct 7, 2009 | 05:20 PM
  #56
Excalibur's Avatar
Nice product. I will be buying soon.
Old Nov 11, 2009 | 07:28 PM
  #57
Hiboost's Avatar
Just waiting on someone with a larger turbo to post gains before and after. I'll have my modified intake manifold installed within the next 1-2 weeks and if that looks favorable in the VDR dyno sheets I would want to do a before and after right at STM's dyno.
Old Nov 11, 2009 | 10:05 PM
  #58
flyguycfi's Avatar
He got the JUN TB and his went into limp mode without getting tuned again.
Old Nov 12, 2009 | 05:54 AM
  #59
Hiboost's Avatar
ECUFlash + DTC Disable codes ftw!
Old Nov 12, 2009 | 06:09 AM
  #60
lex08gsr's Avatar
Sweet! 2 days is fast! Price is right too!
