Evo X Big Bore 64 mm Throttle Body
Old Aug 22, 2009 | 08:23 AM
  #31
LVSBB6's Avatar
Thats the only downside, but if you don't mind waiting a bit longer its worth the wait cos its the biggest one available out there.
Originally Posted by TrackAttack78
You still have to send in your TB to jun since their us office closed you would have to send it to japan. I don't think you will get it in a week. Good luck with that one. Boomba is a vendor that you can contact directly. Good luck talking to someone at jun
Old Aug 22, 2009 | 10:20 AM
  #32
Hiboost's Avatar
Originally Posted by Boomba Racing
It is cheaper and we are in the US. There is the reason that we went to 64mm. Boring TB to 65 mm leaves wall thickness less then 0.02 in (0.5 mm) in some places. It makes it very weak, so we decided to stick with 64mm and not compromise casting strength.
Thanks for the info, sounds like you guys are going about this the right way. The extra 1 mm isn't going to make or break the setup anyways.
Old Aug 22, 2009 | 11:21 AM
  #33
TrackAttack78's Avatar
i totaly agree 1mm isnt going to make much of difference plus having more matrial makes it a safer and reliable. plus the customer support boomba gives you peace of mind.
Old Aug 22, 2009 | 01:45 PM
  #34
Evo J's Avatar
Post dyno results... Until then, this is a paperweight to me as I have seen Bigger TB's do squat on other cars.
Old Aug 22, 2009 | 01:46 PM
  #35
kozmic27's Avatar
Originally Posted by tvieira24
I think he meant he'd get his credit refunded after he provided his original TB....
This is exactly what I meant.
Old Aug 22, 2009 | 02:12 PM
  #36
I'm sure we will see dyno test results soon.
Old Aug 22, 2009 | 03:56 PM
  #37
Evo a Mula's Avatar
I'm planning on buying this but I want to see dyno results 1st
Old Aug 24, 2009 | 08:22 AM
  #38
Boomba Racing's Avatar
This is how much cross section new Throttle Body gains.
Old Aug 24, 2009 | 09:07 AM
  #39
Clipse3GT's Avatar
Looking forward to dyno numbers for the before and after on the same vehicle.
Old Aug 24, 2009 | 10:07 AM
  #40
wht95scort's Avatar
My guess would be 3-6 awhp.
Old Aug 26, 2009 | 11:37 AM
  #41
bump!
Old Aug 27, 2009 | 03:44 PM
  #42
x[corwyn]'s Avatar
bump!
Interesting product, and the milspec one I had on my VIII with the intake manifold porting definitely had a noticeable effect.
I would like to see a before and after on a dyno sheet, and also an idea of the reliability of your product.
Thanks
Old Aug 27, 2009 | 04:58 PM
  #43
I talked to Boomba about this today and they are doing a dyno run on this very soon and as far as reliablity goes . They machined it to 64mm to have more material on the TB and not thinwall the casting. I strongly belive they know what they are doing with their products and the time they
take to test and engineer them. I'm positive we will see positive results.
Old Aug 28, 2009 | 11:12 AM
  #44
Evo a Mula's Avatar
i also talked to them and they said the same thing 1mm is not going to make or break you and i rather be safe or sorry
Old Sep 4, 2009 | 09:45 AM
  #45
Here are dyno results for our shop Evo X.
Our car is stock except for intake inlet ported to 64 mm to match TB.
We got 10 HP gain.
