ATTN Evo 10 E85 users!
Old Nov 3, 2009 | 05:23 PM
  #61
GST Motorsports's Avatar
Originally Posted by logonzojls
any updates on putting a kit together? seems like this thread died off a month ago?
Anyone want to chime in on what i should buy for the fuel system? would be greatly appreciated
More info on BlaqOps:
http://www.blaqops.com/products.html
Old Nov 4, 2009 | 04:58 AM
  #62
coevolve's Avatar
**disclaimer**
I can't hit evoempire at work (dumb network...)
Is anyone running the blaqops X kit? Any idea on the "progressive controller?"
Old Nov 4, 2009 | 09:47 AM
  #63
Originally Posted by coevolve
**disclaimer**
The progressive controller "progressively" brings on the second pump based on MAF hz instead of on/off like a Hobbs switch. Think of it as a progressive meth injection controller for your second fuel pump.
Old Nov 4, 2009 | 01:20 PM
  #64
ETS Michael's Avatar
So after reading most of this thread, the conclusion was the UR hose is not correct? The stock fuel setup is fine with E85? I had a customer bring this thread to me.
Let me know what you think.
Thanks,
Michael
Old Nov 4, 2009 | 04:16 PM
  #65
lowkey's Avatar
Registered User
Is this all done at the pump with the existing wires and ECU controlled voltage or do you need any additional setup aside from the pump assembly?
Old Nov 4, 2009 | 04:21 PM
  #66
There is a control box and wiring. It's all part of that package.
Old Nov 5, 2009 | 09:34 AM
  #67
RB185AFM's Avatar
If you are not going to upgrade your turbo you just need the walbro fuel pump, 1000 cc injectors, 2-1' gates submersible hoses(available at Napa) for intank, a steel mesh inline fuel filter available at jegs or summit. If upgrading the turbo with E85 then get the double pumper. Oh and a wideband. Also if you are using the walbro you can cut the stock fuel housing to fit perfectly with the walbro pump. I did and saved the 150 for the UR piece. All thats needed is a dremel and 20 min.
Old Nov 5, 2009 | 10:26 AM
  #68
murlo26's Avatar
I assume wiring instructions are included and hopefully proposed routing for the wiring with the kit?
I'm probably going to order this when I get back from Cali tomorrow or early next week for when my Red gets here. I will break 500whp on dynojet with my red, I am determined
Then i will need to get a new fuel rail and FPR to raise up my pressure a bit so the 1000cc's will work.
I sent you a PM GST, with pretty much the same question, just curious about the installation.
Old Nov 5, 2009 | 10:49 AM
  #69
Tractionlimit's Avatar
And now you might beat me to it (damn broken transfer case)...
Old Nov 5, 2009 | 11:30 AM
  #70
murlo26's Avatar
I sure hope so I have a lot of supporting mods I need to get first, so I might not be dynoing until spring, but knowing myself I will sacrifice stuff for my new house for new car parts. Who needs blinds anyway, lol.
Old Nov 5, 2009 | 04:33 PM
  #71
RB185AFM's Avatar
I am pissed as right after I buy everything this kit for the double comes out. Now I have to buy another fuel kit when I upgrade my turbo. Would have been nice to just do it once.
Old Dec 1, 2009 | 10:40 AM
  #72
mlomker's Avatar
It's just as bad as computers & home theater gear, isn't it? Seems that all of the fun hobbies are that way.
Old Dec 1, 2009 | 11:22 AM
  #73
murlo26's Avatar
If by fun hobbies you mean expensive ones
Old Dec 11, 2009 | 02:51 PM
  #74
Ultimate Racing's Avatar
Lightbulb
I see this discussion has taken an awkward turn.
Bryan,
Firstly, we have NEVER stated that our fuel pump install kits are E85 compatible. In fact, we have told each and every customer that the parts have not been tested with E85. So I really don't understand why we're even mentioned in this thread
The UR in line-filter wasn't able to handle the pressure at 29psi of boost either as it swelled...
What type of line pressure were you running? These fuel filters are designed for use on OEM applications that well exceed 75psi. 29psi of boost doesn't tell us anything here...and btw, these are not WIX filters. I don't understand why you can't just contact me if you're having issues. I have no problems going over usage specifications with anyone.
Thanks,
Michael
Michael, if you read the original post, you'll see that the OEM black line was also deteriorating from the E85.
Have a good weekend.
Darryl
www.ultimate-racing.com
Old Dec 11, 2009 | 03:05 PM
  #75
Darryl
Darryl,
Sorry, No disrespect towards your product I didn't notice. We haven't put E-85 on our car yet so I will note this. We did have the fuel filter clog after 5,000 miles w/ race gas.
Stock Fuel Pump In Tank w/ Inline 255 Fuel Pump and we put down 730whp
Happy Holidays!
Michael
