serious throttle hesitaion!!! HELP!
Old Sep 23, 2009 | 08:38 PM
ianm12's Avatar
That could happen if you aren't getting air to the intake manifold but it would not drive well at all.
Old Sep 24, 2009 | 05:33 AM
custm08's Avatar
I checked again this morning. RPMs and boost are not, let me repeat, not climbing under WOT. If I'm cruising at let's say 55 at 2500RPM, I'll floor it, watch RPM and boost stay almost still for about two seconds then it kicks in. From what I know, if the clutch was going bad the RPMs would climb with no acceleration.
Old Sep 24, 2009 | 01:15 PM
ScottSpeed21's Avatar
Swap your fuel pump relay.
Is there any jerkiness during the hesitation or everything seems ok and the RPMs just aren't climbing? Any strange noises from the engine? What gear are you in when you go WOT at 2500?
Old Sep 24, 2009 | 01:31 PM
Mad_SB's Avatar
Originally Posted by ScottSpeed21
Could be the good old fuel pump relay.
I had the same thing start happening to me. Trying to run a log in 3rd gear, I'd go WOT and just as the boost was peaking, there was a hard hesitation for a second or two and then it would pull. For me it wasn't the symptoms of a slipping clutch at all.
After reading all about the faulty fuel pump relay, I went out and swapped the fuel pump relay for the high beam relay. All of a sudden the car pulled hard and super smooth all the way to redline.
Try it out, it can't hurt at all.
Yeah, that makes good sense. The OP said he could not hear the engine during the hesitation so I don't think the clutch is slipping. It would not be the first time the symptoms did not sound like a slipping clutch when it was in fact slipping, but in this case it makes sense it would be the fuel pump relay.
I've had this off and on for some time now, hesitation on wot, particularly at lower rpm, like less than 4k. As the op said, lite and mid throttle are fine, it's only when you stab it that you notice the hesitation.
I was thinking it was in the throttle maps or limit maps, but I have adjusted those many times with no change. Never thought about the relay being slow to engage. I'll go ahead and swap my relay when I get back in town and see if that clears up my symptoms, in the mean time I think the op should give it a shot as the revised part number relay is not very expensive and you could even swap it with the horn relay for a quick test.
Good call
Old Sep 24, 2009 | 06:30 PM
custm08's Avatar
I'll swap them tonight and post any results tomorrow after a little driving.
Old Sep 25, 2009 | 08:13 AM
MR. Tim's Avatar
In for info and to try the different relay as suggested. I too have the same issue. It is not the clutch slipping. I too thought it would be in the throttle maps.
Old Sep 25, 2009 | 08:37 AM
Whitewind's Avatar
ahhh relay will make it go lean. Sounds me like boost leak somewhere. Say boost does move for 2 sec? Thats a lot. Check your fuel line going to your intake there is a recall on that to.
Old Sep 25, 2009 | 08:38 AM
Whitewind's Avatar
Left side of your fuel rail and goes to your intake.
Old Sep 25, 2009 | 08:41 AM
Whitewind's Avatar
Recall just came out this month on the fuel line. But never know.
lance6161
Jul 20, 2025 05:19 PM
nshen43
12
Mar 12, 2012 10:30 PM
fast3voviii
Oct 28, 2011 09:17 PM
wevo1
37
Dec 31, 2008 04:00 AM
