hard to get in reverse
Old Sep 30, 2009 | 04:10 PM
jmsrt4's Avatar
Since the day i got my evo ive had a problem putting the car in reverse. When i sit in the car after starting it the car doesnt seem to want to go into gear eventually after going up and down from first to reverse it will go in but its starting to get old. Anyone else have this problem? Also sometimes it appears like its in reverse but it almost feels like its in 4th and the car just wont move and it will pop out
Old Sep 30, 2009 | 04:56 PM
Breakaway's Avatar
Is yours an MR or a GSR?
My MR isn't happy getting into reverse immediately after I turn the car on. I usually wait at least 5 seconds for all the electronics to be stable before going into reverse - I've never had an idle since.
Old Sep 30, 2009 | 05:05 PM
buchnerj's Avatar
Mine fights me to get into reverse after a cold start too. Once shes warmed up all is well, but just gotta wake her up to cooperate. Maybe a different fluid would help...
Old Sep 30, 2009 | 05:06 PM
lowkey's Avatar
Registered User
Is this your first manual car?
Old Sep 30, 2009 | 05:09 PM
guapoholic's Avatar
Old Sep 30, 2009 | 05:56 PM
jmsrt4's Avatar
nah its my 3rd manual car and i know how to put a car in reverse the car just fights me and i was wondering if anyone else has this problem.........my other cars were a civic and srt4 and neither one had any issues putting the car into reverse maybe once in a blue moon but my evo does it every day
Old Sep 30, 2009 | 06:54 PM
gizmotoy's Avatar
I was kind of wondering the same. All of the manuals I've had have done something similar. Just push the shifter back into first, and then it'll easily slip down into reverse again. Problem solved. Worst case, roll it slightly forward and then into reverse.
But it sounds like you already knew the solution. Just learn to deal with it, I guess? There's nothing you can do about it.
Old Sep 30, 2009 | 07:58 PM
lowkey's Avatar
Registered User
Mine too, its normal.
Old Sep 30, 2009 | 08:03 PM
GaBe511's Avatar
I know first and reverse share syncros, at least on hondas they do. When my honda had problems goin into first or reverse, i would let it roll a little bit, like move which way it could, then it cooperates.
Old Sep 30, 2009 | 08:58 PM
overdrive1's Avatar
try replacing the fluid... that should help a bit
Old Sep 30, 2009 | 09:32 PM
Dr. Ev0L's Avatar
A spur cut gear (reverse) is used so it can unmesh with the other gears. helical gears are always in mesh and don't separate ( forward gears using sycros/hubs to keep them from free wheeling on the shaft when in use) i don't believe a reverse gear uses a sycro/hub but rather your sliding the entire gear into mesh. if they arnt aligned some what, its gonna take a little more effort or rolling of the car to get it in.
not sure if the evo works that way. i know it works a little bit different then normal, but should be something like that.
Old Sep 30, 2009 | 10:49 PM
wtam1100's Avatar
Same thing happens in my car in durring cold starts in th morning and I already switched to amsoil. I sometimes put it in thrid, then in reverse or let it roll down my drive way for like a foot then it goes into reverse easier.
Old Oct 1, 2009 | 06:45 AM
JonBoy's Avatar
Have you tried running through the gear pattern before you try reverse? In other words, start the car, wait a few seconds to get the clutch bearing(s) properly lubricated, then depress the clutch and slide the transmission into 1st, then 2nd, then 3rd, then 4th, then 5th. Then, push it back to neutral, release the clutch, then depress the clutch and put it into reverse.
I've found with vehicles that have a tighter or worn gearbox, if you do this, it will generally shift into reverse easier. It may be a lubrication issue but it's probably just the fact that the gears are slightly misaligned initially and the shifting sort of brings them all into easy alignment.
Old Oct 1, 2009 | 01:04 PM
LagginTimes's Avatar
From what I understand, reverse on the GSR uses the 1st and 3rd gears. I read on these forums a while ago that shifting to 1st and then 3rd before going into reverse will help if you get locked out. The one and only time I have had difficulty getting into reverse was a few weeks ago leaving work. 1st->3rd->reverse, and I was on my way.
Old Oct 2, 2009 | 08:22 AM
Laz's Avatar
Laz
Yeah LagginTimes and the others are right. Shift into other gears and it helps. Mine does it probably 50% of the time when I start it up in the morning.
