GT3076R - Internal WG Failure
Old Feb 21, 2010 | 07:01 PM
  #31
linjy2's Avatar
Bumping this up.
So my cars been NA for the past 6 month... and I finally have a weekend open to work on it. Here is the result.
Now to contact my seller tomorrow to get some warranty work. Hopefully they won't give me the run around.
Old Feb 21, 2010 | 07:06 PM
  #32
Clipse3GT's Avatar
Looks like you got some oil in there...
Old Feb 21, 2010 | 07:23 PM
  #33
linjy2's Avatar
hmm... I assume that is bad? I did spray it with lots of lube before I took it off. Not sure if that is lube or oil.
The turbo has only 1200+ miles before the flapper broke off... =(
update: just got done taking the turbo off. took me 3 hrs, not bad i say..
that oil was from my gloves when i tried to feel if the flapper was still there when i took the downpipe off, cause i didnt see oil anywhere else inside.
Old Feb 22, 2010 | 06:07 AM
  #34
Hiboost's Avatar
The Oil appears to have been rubbed on sometime after the last engine start, that area is way too hot to have somewhat fresh looking oil just sitting around in only those spots.
I couldn't have imagined going 6 months with normally aspirated setup, I would have gone crazy! Even for daily driving, the car is often in the 3-5 psi range on light acceleration and without that it really bogs down the car. I sent you a PM but basically you should be able to leave what's left of the flapper in there provided it doesn't leak exhaust gas through the pivot arm.
I did end up welding an O2 bung into my testpipe and that is working just fine for the AEM Wideband setup.
Old Feb 22, 2010 | 07:07 AM
  #35
tsitalon1's Avatar
That is a GROSS defect of such a critical part from such a well known and experienced company....Shame on them!
Old Feb 22, 2010 | 01:45 PM
  #36
CBRD's Avatar
pm-ing you!!
cb
Old May 29, 2010 | 11:35 PM
  #37
chkmgnt59's Avatar
so... this turbo is fine now correct? i mean any new ones will have the new wg setup and not be defective?
power wise, is this turbo better than a fp red, or about the same? and I wonder if FP couldnt take one of these and gut it for some 35r action.....
Old Jun 1, 2010 | 12:52 PM
  #38
spdracerut's Avatar
Don't know if it's back out yet, but Dent Sport Garage seems to be running one:
http://www.dentsport.com/2010/05/11/...-no-new-posts/
It's about 1/3rd of the way down the page.
Old Jun 1, 2010 | 01:01 PM
  #39
CBRD's Avatar
the only way id run this turbo housing is with the big hotside and 35R internals,
the 3076R leaves a bit to be desired in any application in my opinion.
cb
Old Jun 1, 2010 | 02:00 PM
  #40
murlo26's Avatar
cb
So you could take the 3076 and upgrade it right?
Now that sounds tempting.
Old Jun 1, 2010 | 02:04 PM
  #41
CBRD's Avatar
or maybe a billet TAK33R wheel
cb
Old Jun 1, 2010 | 02:06 PM
  #42
murlo26's Avatar
cb
Would that wheel go into the 3076 or are you referring to the kit you are working on?
PM me if its the 3076...curious what this would cost.
Dave
Old Jun 1, 2010 | 02:28 PM
  #43
CBRD's Avatar
it COULD fit, if we machined it
larger turbine too
cb
Old Jun 1, 2010 | 03:29 PM
  #44
DannyK24's Avatar
TAK33R price quote naow!!! almost got enough saved up for the BBK and manifold.
Old Jun 1, 2010 | 03:42 PM
  #45
CBRD's Avatar
pm me, so im not a hijacker!
cb
LCS
11
Mar 31, 2016 07:58 PM
black_beauty
Nov 17, 2014 07:10 PM
svt_lightning01
Mar 31, 2011 01:08 PM
11secMR
May 21, 2008 11:56 PM
deathtracks
Feb 17, 2008 06:15 PM
