ACD Control: Howzit work?
Old Oct 25, 2009 | 08:44 PM
WAM's Avatar
WAM
I know there's a hydraulic clutch system that locks the ACD upon ECU command. But what does the ECU actually command? Computer output signals don't power hydraulic pumps. So what's between the ECU and the hydraulics? Stepper motor maybe....solenoid valve etc? Or does the hydraulic pump maybe receive variable voltage from some sort of controller device?
What I'm really wondering is if I can temporarily hack the ACD control system and put in manual dash switching to get full lock, full unlock etc. Before I get into the world of ACD reflashes, I'd like to know exactly what does what to the handling.
Old Oct 27, 2009 | 11:18 AM
WAM's Avatar
WAM
So I take it you guys don't know either.
I did find out if you pull the ebrake 1-click it shuts off the ACD clamping. That gives me at least something to test.
Old Nov 23, 2009 | 04:26 PM
GiGas's Avatar
Not shure for the evo X but the IX has a separate ACD/S-AYC ECU. That ECU have sevle indput devices like abs sensors, g-sensor, stering sensors, breake sensors etc.
A hydraolic pump create approx 1 kpa preshure, the ACD/S-AYC ECU controles two proportional valves one for the ACD hydraolic dual plate clutch in the front, and the other supports a directional valve to the S-AYC in the rear.
My guess will be that Evo X has a simular system or maby the same system.
Pref7
22
Jan 6, 2023 04:18 PM
joseph143
Jan 23, 2018 09:40 PM
TommiM
Aug 15, 2012 06:41 PM
LancerNL
Apr 3, 2011 04:42 AM
RSMike
13
Feb 21, 2011 10:01 AM
