ASC Off Light Turns on on 5th Gear WOT
When I am in 5th gear, when I go WOT, all the sudden it feels like fuel cut. The ASC off light turns on and the service light pops up. The engine does not respond to any gas pedal input and I have to brake to a complete stop. Then the engine idles horribly at 2000 rpm. I shut off the car for 5 seconds, restart it, and then the ASC light goes away. Anyone else have this issue or have any input? Thanks!
You guys are likely hitting boost cut or a limp mode. Verify you aren't exceeding the boost limits load percent values and look into using the DTC disable codes to avoid setting off airflow and torque limit table limp modes.
bacquerel
Nov 4, 2010 08:33 AM
delkat
May 17, 2010 08:21 PM
