Meth?
Old Nov 17, 2009 | 03:31 PM
mrMTB's Avatar
This forum is required reading if you're thinking about putting meth on your vehicle.
https://www.evolutionm.net/forums/wa...ction-nos-173/
All your questions are answered in there...
Old Nov 17, 2009 | 03:32 PM
Yearlongstorm's Avatar
I have an aquamist hfs1 with 100% meth with an FP red an iveytuned putting 455whp 429wtq 33psi. I love meth despit it being risky and somewhat scary running it. But its a chance you take for cheap big hp gains.
Old Nov 17, 2009 | 06:44 PM
yahu's Avatar
^455whp or 555whp? Is that a 64mm or 80mm housing? Just curious on new data! Thanks!
Old Nov 17, 2009 | 07:49 PM
Freebs's Avatar
The only thing risky about running Alky injection is if you are running some very aggressive timing/boost/AirFuel ratio and you run out and don’t notice. This is when engines are blown and a friend of mine did this on his Grand National and it cost him an engine. That’s why you put a low warning light and if you can set it up to have a pressure sensor that when alky pressure drops it switches you over to a safe tune automatically or at least switches your boost to a lower psi. This way you don’t need to set up another tune, it just would drop your boost from say 30psi down to a safe 20psi.
Old Nov 17, 2009 | 08:42 PM
yahu's Avatar
^I'd take a blown engine over a leak + heat/spark. Methanol is very flamable, but similar concept - put in some warning system and failsafes as Freebs mentioned and you'll catch both issues!
Old Nov 17, 2009 | 09:25 PM
BLKCarbonEVO's Avatar
Dan, 455hp is about right on a DJ for a Red on the X. I think the highest Red that I have seen on the X was 480-490ish on a fully built motor running Q16 on 37-38psi. They also don't come in an 80mm housing. The Red for the X is not even comparable to that of a IX.
Also don't look for a Black for the Xs... Robert won't be making one because the market is not there and not sure that it ever will be. Most X guys will make much more power going to a T3 or a T/4 setup
Mikey
Old Nov 17, 2009 | 10:51 PM
yahu's Avatar
lol - I keep forgetting this is an X thread. my bad!
Old Nov 18, 2009 | 06:49 AM
Mikey
sorry for responding so late. but ^ +1. Stock motor to. No internals done
Old Nov 18, 2009 | 08:44 PM
^ The Xs seen to hold power just as well as a IX... Maybe even better
nikush
Feb 11, 2015 05:08 PM
outlaws69
Northwest Region
12
Feb 1, 2011 07:02 AM
MR. EVO MR
Driving Techniques
22
May 25, 2010 10:00 AM
EvoJoeIX
Mid-Atlantic Region
12
Aug 2, 2008 09:45 PM
1NastyMR
Mar 16, 2008 06:45 PM
