ACD C2100 code
Old Dec 6, 2009 | 06:06 PM
mooserov's Avatar
ACD C2100 code
I searched the forums and didn't find any info.
my 5 speed GSR just threw this code while I was on the highway. I got a tone from the dash, the cruise kicked off and the speedo dropped about 40 mph. It happened a couple of times and when I stopped and pulled codes with my acessport I got acd c2100.
The front tires are worn more than the back. 15000 miles on the car.
Any help will be appreciated.
Old Dec 6, 2009 | 06:26 PM
mooserov's Avatar
Ive done some more searching 'round the web and I can't find anything relating to this. Has anyone seen it or has a reference?
Moose
Old Dec 6, 2009 | 06:30 PM
chkmgnt59's Avatar
thats so funny, I threw that same code yesterday at the track. i took a turn wide and my front two went off track before I was able to correct and threw this code. i cleared it and it never came back (also never went off track again)
but sorry, I have no clue what it is
Old Dec 6, 2009 | 06:32 PM
mooserov's Avatar
huh, I wonder if it has to do with my tires being more worn in the front. It was in the second hour of a 2 hour trip, so maybe a slight mismatch would show up. I really need to get new tires.
Old Dec 7, 2009 | 05:24 PM
mooserov's Avatar
bump for info
Old Dec 7, 2009 | 07:15 PM
gunzo's Avatar
battery votage malfunction ..
did something to the wiring ?? connector lose ??
Old Dec 7, 2009 | 07:50 PM
mooserov's Avatar
it's an adc trouble code that cuts power when it's thrown to prevent damage. I think it has to do with overheating, but I can't find any information on it.
Old Dec 8, 2009 | 02:24 AM
gunzo's Avatar
Originally Posted by mooserov
it's an adc trouble code that cuts power when it's thrown to prevent damage. I think it has to do with overheating, but i can't find any information on it.
it is battery voltage malfunction .. You get this code when etacs voltage to the acd/ayc ecu drops below 9v
Old Dec 8, 2009 | 09:02 AM
mooserov's Avatar
Oh thanks. I need to check my battery connections. Installed an audio amp a while back
Old Dec 8, 2009 | 05:53 PM
mooserov's Avatar
Checked all my wiring and it's good. I haven't been able to climb under the car and check things. Why would chkmgnt59 have the same code when he dropped 2 wheels off the track?
On a side note, I updated my acessport and map to the new one that doesn't throw the p1235. nice.
Old Dec 8, 2009 | 07:16 PM
chkmgnt59's Avatar
i'm not positive the code came when my front two went off track. I just know it came during that session. I was slightly busy at the moment I was off track so I didnt notice if the code came up right then..... :-)
Old Dec 8, 2009 | 08:31 PM
mooserov's Avatar
at least it is another person seeing the code. I was in the middle of a trip on smooth highway, no bumps. going 78 mph on cruise control. Wiring problems usually present on a rough road or transition in my experience. Unless it is wind whipping a cable under the car or in the engine compartment. It hasn't happened again. I'll be making the reverse trip friday, so I'll watch for it.
moose
Old Aug 25, 2012 | 10:24 PM
Spc-andara's Avatar
This just happen to me an hour ago and I found the problem I lossend my battery b cuz my wife car was acting up. So instead of a bust I just changed the battery. When I put it back I forgot to tighten the screws. I guess while I was driving it came off the polarity connectors so I thigted and problem fix.
dragon831
Jun 6, 2015 05:30 PM
Ridge727
Aug 12, 2014 06:01 PM
Iowa999
Jul 26, 2013 09:29 AM
bluegsr
Jun 18, 2010 05:22 PM
salvatruco2004
13
Jun 10, 2010 05:45 PM
