Evo X E85 Conversion How To & Discussion
Old Jan 26, 2010 | 05:00 AM
  #61
mlomker's Avatar
Originally Posted by saytheb
make your own setup that you do NOT use a cotton sock.
If someone knows a source/part number for an 8/9 sock then please let me know. I need to fix my UR kit single-pump install. I tried emailing Blaqops but no response...from the sounds of things, they must be busy.
Old Jan 26, 2010 | 06:08 AM
  #62
murlo26's Avatar
I am using the sock from the DIY install posted on the forums. It is probably cotton. I will take pictures of my setup when I take it out this week. Sending in for an e85 rated blaqops double pumper. I have been running great still so I am curious to know how it will all look.
Old Jan 26, 2010 | 08:35 AM
  #63
evolvedx's Avatar
I had the standard issue Walbro sock in mine running E85. I recently replaced it w/ an 8/9 sock from Blaqops. The Walbro sock is cotton and it had not decomposed, but it had turned black. Yes black. Yeah, I didn't care for that much either. I imagine decomposing was the next step. Anyhow, before I got a sock from Blaqops I did some probing around to try to find and 8/9 sock. Apparently, they're hard to come by, and Blaqops has some super secret source he gets them from. I think it's $20 shipped if you order one from him though; definitely do it.
Old Jan 27, 2010 | 05:25 AM
  #64
mlomker's Avatar
I've decided to work with BlaqOPs on a custom setup. It'll be a Full Blown hanger with the BlaqOPs boost progressive pump/controller.
It's a much more expensive way to go but having the car down to do a core exchange would be expensive for me anyway (I'd have to rent a car). I'll undoubtedly post a thread on one of the forums showing the finished product.
Old Mar 5, 2010 | 09:17 AM
  #65
ikt's Avatar
ikt
I'm getting my injectors today, have the AP flash, gonna run stock fuel pump, but i will swap out the inline filter...
Old Mar 5, 2010 | 03:42 PM
  #66
Fourdoor's Avatar
E85-E70 tunes aren't a necessity.
My tuner said many people here in MN run their same tune and don't have issues. I am still on my E85 tune and it switched to E70 already. No problems.
Going from E85 in the summer to E-70 in the winter is ALMOST seamless... if you have an aggressive E85 fuel tune combined with slightly more conservative timing curve tune.
The E-70 is slightly less knock resistant than E-85, so you need to run it a bit richer... this automatically occurs due to the E70 having more gasoline in the mix.
Personally, I will get my E-70 tune done professionally on the dyno, and then when summer hits I will tweak the tune a bit myself on "pure" E85 with the handy dandy Tactrix cable.
The last time I ran E85 on a regular basis was in my EVO VIII with the AEM EMS system. There was a difference in E70 vs E85 but it was not extreme. Changing from Gasoline to E85 or back was more of a tune headache even if you ran the tank almost dry.... this makes a HUGE difference on the dyno tune! When I did my original E-85 tune it was probably actually E-70 and still had a couple gallons of gasoline in the tank when filled up with the ethanol I was pushing 30 psi and making 500 wheel HP on Buschurs dyno at 100% duty cycle on 1000cc injectors. After running two tanks of E-85 through the car I was limited to 26 psi at 100% duty cycle.
Keith
Old Apr 30, 2010 | 02:47 PM
  #67
Fourdoor's Avatar
Hey goofygrin,
I just received my double pumper fuel system for my Ralliart from Buschur Racing, and I didn't realize they don't come with a fuel filter (the double pumper for VIII included a filter). Do I just need two fittings from http://www.midwayautosupply.com/pm-4...t-800-084.aspx along with the Jegs or Golan filter specified and a length of ethanol compatible fuel hose to make up an under hood fuel filter setup?
I have been running E-85 on the bone stock fuel system for months now, but it couldn't keep up with my power level... hence the double pumper and 1000cc injectors
Later,
Keith
Old Apr 30, 2010 | 02:56 PM
  #68
mlomker's Avatar
Yup, you just need 30r9 hose for underhood and it's quite common and reasonably priced.
Old Aug 26, 2010 | 11:48 AM
  #69
lakay888's Avatar
hey guys is anybody running two maps e85 and 91oct that tou can switch if you need to, what do i need to do this, is it possible, im dying to switch to e85 but I daily drive the car and dont want to store too much gas in my garrage, im at least 80mls from e85 pump, thanks for any info
Old Aug 29, 2010 | 08:11 PM
  #70
aftershock141's Avatar
You need to search for Tephra's threads. He has alt map switching.
Old Sep 3, 2010 | 07:24 PM
  #71
MACKLIN's Avatar
I have the ams fuel rail and fpr. How could I use a inline fuel filter with them? Would I just cut and install one before the fpr?
Old Oct 3, 2010 | 02:36 PM
  #72
GR8WHITE RS's Avatar
this is a great thread. thanks for taking the time to do this its really helpful to us newbies.
Old Oct 5, 2010 | 08:35 AM
  #73
Fractur3's Avatar
Very useful, I'm surprised I just found this!
Old Oct 5, 2010 | 04:47 PM
  #74
42oz's Avatar
do that many people on here run e-85?
Old Oct 5, 2010 | 04:55 PM
  #75
dek0026's Avatar
a few of us do.
goofygrin has dropped off the face of this forum.
