Stock Evo X intercooler size??
Old Jan 1, 2010 | 04:58 PM
cpunlamd's Avatar
I never had my stock intercooler off my car, so I dont have the actual specs on it. Im in the market to upgrade my stocker. There are a ton of after market intercoolers, averaging a core size of 20 wide, 12 high and 4 inches thick. The problem is, I cant make an educated decision if I dont know where we start (stock size).
Can anyone with the stock intercooler off the car, post some pics and specs?? Thanks in advance..
Old Jan 1, 2010 | 05:06 PM
UT_EvoX's Avatar
Size doesn't matter much when the stock intercooler core is relatively inefficient compared to aftermarket ones
The stock core is actually pretty sizable; I lack specific dimensions, though.
Old Jan 1, 2010 | 05:08 PM
cpunlamd's Avatar
Top pic: Buschur 12"H x 4 1/2"W x 18"L
Bottom: Stock
[IMG][/IMG]
Bottom: Stock
[IMG][/IMG]
(IMO someone has got to remove the plastic shrouds on the side and make a much WIDER core.)
Old Jan 1, 2010 | 06:55 PM
Hiboost's Avatar
There's quite a bit of things in the way that prevent it from being more than about 20" wide. Not saying it's impossible but you would have to heavily modify the front end to account for it and maybe delete the AC. The stocker is about 2.5" thick and likely still able to support 500-550 crank HP but at that point it will definitely be a restriction and prone to heat soak after multiple gear pulls. I think most people will do great with a 4" thick core from ETS or similar.
Old Jan 3, 2010 | 07:05 AM
KPerez's Avatar
A little use of our search engine is in order.....Herein (https://www.evolutionm.net/forums/ev...tercooler.html) you will find the info U are looking for and then some.
Later, Ken
Old Jan 3, 2010 | 07:15 AM
cpunlamd's Avatar
Later, Ken
Thanks. There's a lot of good info there..
5LEEPERISAH23I
Nov 27, 2011 05:12 PM
PPI
Dec 11, 2010 11:46 AM
EViR
10
Nov 1, 2009 07:52 PM
Emperor666
13
Sep 8, 2007 09:11 PM
SophieSleeps
Jul 21, 2007 12:12 AM
