exhaust rubbing the driveshaft bracket...
Old Jan 1, 2010 | 07:22 PM
Methodical4u's Avatar
Has anyone else had this problem? What did you do about it? My exhaust is super tight under there and CANNOT be shifted... any ideas?
Old Jan 1, 2010 | 07:26 PM
smokedmustang's Avatar
We all have. Get some foam (Heat resistant of course) and put it where it's rubbing. or rebolt it on. there is a little "Play" in there for that. You will be fine.
Old Jan 1, 2010 | 07:37 PM
oh ok... I just thought I would check... any particular foam I should get? It won't rub a hole in the foam or anything?
Old Jan 2, 2010 | 06:12 PM
any other thing to use besides foam? Just curious..
Old Jan 2, 2010 | 06:17 PM
I used that aluminum foil hi heat exhaust foam. just put it on the body part where it's rubbing. I also used that heat wrap around my exhaust too. did you try to rebolt the exhaust??
Old Jan 2, 2010 | 06:41 PM
no... I don't understand how it would make a difference?
Old Jan 3, 2010 | 11:40 AM
ScottSpeed21's Avatar
My cat pipe was just barely touching one of the bolts on the driveshaft bracket. I cut the bolt off.
Old Jan 3, 2010 | 03:24 PM
hmmm, I suppose that's an idea... i'd rather not cut anything on the car if I can help it though. Once it warms up here i'll put it back up on the jack and see what I can do.
Old Jan 4, 2010 | 05:58 AM
↑ It's not like you're going to hurt anything, there are other bolts holding that bracket on, and there's no stress on the bracket at all.
Old Jan 21, 2010 | 09:07 PM
well I did cut the bolt off and for about 2 weeks or so I guess it was ok.. a little rattle from the heat shields, but NOW the problem is the exhaust is rubbing the bracket itself and making all kinds of noise. Is the best thing just to wrap the exhaust in that area?
Old Jan 21, 2010 | 10:11 PM
Spazpilot's Avatar
I did the exact same thing with my AMS HFC. Works perfect and I still have the cover held in place by the other two bolts.
Old Jan 21, 2010 | 11:06 PM
delete or close this thread... had the test pipe on the wrong way like a dumb*******.
xmel012
Jun 17, 2017 03:15 PM
jerseygts
Jun 17, 2013 10:26 AM
dsevo
Sep 21, 2008 07:03 PM
evo_il8
Jul 2, 2005 06:11 PM
hueman
Feb 21, 2005 11:03 PM
