DW 1000cc Inj.
Old Jan 20, 2010 | 01:07 PM
darwin_evo's Avatar
DW 1000cc Inj.
Hello,
Just purchased a set of DeatschWerks 1000cc Fuel Injectors.
They came sealed in the box, however they have some marks
On them, as if they were used. They were all covered with some
Cleaning material too (sonax or something). Is this normal?
Tks
Old Jan 20, 2010 | 01:09 PM
murlo26's Avatar
They flow test every injector after manufacturing, perhaps this is what you are noticing.
It should have came with the data on the flow testing.
Old Jan 20, 2010 | 01:23 PM
tsitalon1's Avatar
Originally Posted by darwin_evo
Hello,
Tks
Did you buy them from a company or off ebay?
Old Jan 20, 2010 | 01:28 PM
darwin_evo's Avatar
From a vendor here on evom which i won't disclose, as the purpose of this thread is to know if it's normal for these injectors to come in this condition when brand new.
Old Jan 20, 2010 | 02:57 PM
saytheb's Avatar
Check the marks, they may be the injector numbers.
Mine came, box opened, with the cleaner covering them as you described. They are flow tested and matched before shipping out, no issues.
Just make sure you have o rings at the top and bottom of each injectors, the numbers match those on the flow chart (if provided), and the super lube they provide is still in the box.
Old Jan 20, 2010 | 04:02 PM
Clipse3GT's Avatar
I prefer to use clean motor oil to the lube they include. That lube just makes a mess.
Old Jan 21, 2010 | 10:16 AM
Evo a Mula's Avatar
they are all flow tested
Old Jan 21, 2010 | 08:41 PM
cpunlamd's Avatar
I really question the performance of the DW1000. Apparently they use a totally different nozzle design when compared to their 800s and smaller. The smaller injectors had a multi-perforated nozzle which spread an equal mist when spraying. The new DW1000 has only one hole on its nozzle.
FYI: DW made their name through the performance of the multi-perforated nozzle design for the past few years. Im afraid this DW1000 will not perform as well. They actually removed the DW1000 line from production a few months back because of some issues they had with it. Hmm.......
Old Jan 22, 2010 | 08:26 AM
mlomker's Avatar
How would you know if it wasn't performing? Pretty much anyone running E85 uses them, including Gates. My car runs...
Old Jan 22, 2010 | 08:32 AM
cpunlamd's Avatar
It was told to me by one of their distributers/beta testers here in the tri-state.
Old Jan 22, 2010 | 09:51 AM
saytheb's Avatar
@Clipse3GT: I just know how to use Lube I guess
This are pictures (very poor) of my DW1000s
Old Jan 22, 2010 | 11:39 AM
murlo26's Avatar
I haven't heard anyone having any problems with the 1000's.
I also run them and my car works great.
Old Jan 22, 2010 | 12:13 PM
darwin_evo's Avatar
This is the second set of DW1000cc we buy, but I didn't ope the 1st set to see if it came the same way or not (and the guy who installed it said he doesn't remember if they came the same way). Anyway, we installed this set and they work fine.
Tks
dmotors
Jan 17, 2016 02:30 PM
motion3131
Northwest Region
Jun 1, 2011 09:46 AM
evo9ben
Northwest Region
Sep 10, 2010 06:24 PM
evoevo8
South Region
Apr 19, 2010 04:43 AM
Gbrownn08
Sep 8, 2008 08:41 PM
