Ceramic Coating
#32
I think on a non-turbo setup it will last fine, but not with the high temperatures on a turbo setup.
#43
After 40k+ miles, yes it definitely is being effected by the heat. The outer white layer has also cracked a little as well. However, the gray base coat layer which adheres to the metal is still perfect.
I drive this car every day, it's been on the dyno multiple times, and I definitely put the power to good use when I drive. I'm not disappointed at all and I'm still very confident in it's effectiveness.
-Jalal
-Jalal
#44
PPI did the porting on on the manifolds for my car/Swain coated. BBE on the intake and White Lightning on the exhaust mainifold-hotside-O2 housing. The drop in engine bay temps was worth every penny. And the stock EX. mani. is showing some discoloration/chipping after a few track seasons and 36K miles. I am very tempted to BBE coat the new CBRD I/C before it gets installed as well as the intake pipeing. Overall, I have been very pleased with the Swain coatings as they work well. Pete
