Identify these X trubo parts
Old Jan 28, 2010 | 03:45 PM
Kieffer87's Avatar
From this picture can you identify the 3 brackets (3, 4, and 7) on the parts drawing.
I'm trying to figure out if 3 is the WGA bracket and 4 and 7 are these two:
1555A320 O2 housing bracket
1515A166 Compressor housing bracket
For whatever reason I can't find a place to buy OEM parts that has both illustrations and part numbers (besides the stealership of course). Mitsubishiparts.net doesn't have any illustrations and this site doesn't have part numbers.
Just getting the rest of my parts gathered for my X turbo swap on my ralliart. However I want to make sure I have everything and don't get dupicates.
Old Jan 29, 2010 | 07:10 AM
RussellM's Avatar
Plat Vendor
Originally Posted by kieffer87
from this picture can you identify the 3 brackets (3, 4, and 7) on the parts drawing.
I'm trying to figure out if 3 is the wga bracket and 4 and 7 are these two:
1555a320 o2 housing bracket
1515a166 compressor housing bracket
for whatever reason i can't find a place to buy oem parts that has both illustrations and part numbers (besides the stealership of course). Mitsubishiparts.net doesn't have any illustrations and this site doesn't have part numbers.
Just getting the rest of my parts gathered for my x turbo swap on my ralliart. However i want to make sure i have everything and don't get dupicates.
1 turbo 1515a198
2 inlet gasket 1515a184
3 bracket 1515a166
4 bracket 1515a180
5 outlet fitting 1555a423
6 outlet gasket 1555a289
7 bracket 1555a320
8 protector 1555a424
9 protector 1555a370
10 return tube 1225a181
11 tube gasket md194403
12 tube oring 1310a344
13 feed line 1225a155
14 line gasket mf660064
15 feed tube gasket 1226a003
16 outlet fitting 1515a150
17 outlet fitting gasket mr281085
18 inlet fitting 1542a042
19 inlet fitting gasket 1515a053
Old Jan 29, 2010 | 07:23 AM
Kieffer87's Avatar
You are the man! Thanks!
Faust
76
Nov 6, 2018 06:47 PM
kaj
Jul 5, 2016 03:45 PM
warlo3k
May 1, 2016 03:45 PM
golgo13
MitsubishiParts.net - WA
37
Jan 14, 2015 08:55 PM
Faust
Apr 26, 2007 09:02 PM
