Dom2.0 requirements
Old Feb 16, 2010 | 09:29 PM
Nex1's Avatar
Dom2.0 requirements
I'm planning on upgrading my turbo to a Dom2.0.
What supporting mods are needed to run this turbo?
The mods that I will have will be:
TBE, turbo inlet, Perrin intercooler, UICP.
I know I will need larger injectors(probably 800cc). What else would I need?
Old Feb 16, 2010 | 09:35 PM
HR2L's Avatar
Fuel Pump would be helpful. Honestly I would go 1000cc Injectors. Other then that, you'll need nothing else. I would also see if it is possible to have the Exhaust side ported as well as your stock manifold (optional/non-necessary).
Oh and obviously you'll need to be tuned.
I have a Dom 2. Very nice turbo on 91. Enjoy!
Old Feb 17, 2010 | 01:35 PM
Nex1's Avatar
fuel pump absolutely required? Or will stock suffice?
Goal is around 400HP daily driver.
Old Feb 17, 2010 | 04:42 PM
HB Speed's Avatar
If you are looking for 400whp I would get the fuel pump why skimp out on a couple hundred dollars if you are buying injectors and turbo?
Old Feb 17, 2010 | 04:45 PM
sohcpunk's Avatar
Anyone know what type of MPG you'll be looking at after the turbo upgrade with fuel pump and injectors?
Old Feb 17, 2010 | 04:54 PM
HB Speed's Avatar
It will depend on your driving. in boost look to lose a few MPG's but off boost it should be similar to stock
Old Feb 17, 2010 | 05:16 PM
SiC's Avatar
SiC
Does your TBE include a test pipe or a HFC? I also have a Dom2 and when I went from a 200cell HFC to a test pipe, I instantly gained close to 30whp.
Old Feb 17, 2010 | 08:49 PM
abazaba410's Avatar
Is the stock fuel pump only good until 400whp? It seems like it could wait I havent seen alot of info on them though.
mygsx
Oct 19, 2016 04:33 PM
Noize
Evo X Dyno Results
20
Apr 25, 2016 04:06 PM
TURBO_S2K
Dec 23, 2015 11:04 AM
shiftslow
Aug 11, 2015 10:19 AM
GST Motorsports
Mitsubishi TC-SST Discussion
22
Apr 8, 2010 12:35 AM
