please help O2 sensor dethreaded
Old Feb 18, 2010 | 09:41 AM
midwestX's Avatar
Some amateur shop guys damaged the thread of my O2 sensor that goes in the cat while taking it off the car.
Now my question is can I have it welded and get rid of the CEL light and fill the hole in the cat??
thanks a lot
Old Feb 18, 2010 | 09:47 AM
►EvolutionX◄'s Avatar
Hes probably not an amateur , its damn hard to get that thing out without cross threading it, the guys at my shop told me if I weld it it will ruin it due to the high heat, but who knows, you could try and if it doesn't work get a new 1, bad thing is they are 300 something dollars. You can get a bolt to fill the hole temporarilly
Old Feb 18, 2010 | 09:52 AM
Kilratio's Avatar
Have a shop grind/cut off the old bung and weld a new one to it then reinstall
O2 sensor. Its simple, and should cost less than 50 bucks.
Old Feb 18, 2010 | 09:53 AM
Chele's Avatar
Re-weld a new bung in or just helicoil it.
Old Feb 18, 2010 | 09:57 AM
I dont think you guys understand, its not the BUNG, its the SENSOR whose threads got mauled.
Old Feb 18, 2010 | 11:24 AM
Clipse3GT's Avatar
Shop damaged it, shop can pay and fix it now...
Old Feb 18, 2010 | 11:28 AM
VIIIrs's Avatar
^^^^ yea that!!!! that's totally bull ish dude i would make them get you a new 02 sensor
Old Feb 18, 2010 | 11:45 AM
evoyao's Avatar
I damaged mine too when I installed test pipe. It damaged first 2 thread, luckly I can still tight it back. But I did put some exhaust sealing/antilock tho.
Old Feb 18, 2010 | 12:02 PM
autoxer_minh's Avatar
For sure you need to have that shop man up and fix the problem that they caused. With that said I just did the same thing to my O2 sensor when I swapped in a HFC but with the help of the some internet searching I was able to fix mine. The threads on the sensor were pretty jacked up but I went and got a small file set at Harbor Freight for $8. I used the file with the sharpest edge to cleanup the threads. It took about 30 minutes to do but the sensor went back in just fine with antiseize and a little more effort than clean threads would take.
BTW, if you ever have to remove an O2 sensor, the advice floating out there is to do it before the exhaust cools down too much. Metal does expand and contract with heat so doing this while everything is still hot might help. Just make sure you are wearing appropriate safety gear so you don't burn yourself.
Old Feb 18, 2010 | 12:44 PM
Ltdanish07's Avatar
You could always get a die and chase the threads. But honestly, save yourself the work and have the shop cover it. They were the ones who screwed it up so they are responsible.
Old Feb 18, 2010 | 01:03 PM
goofygrin's Avatar
rear o2 sensor?
Just plug the hole, remove the sensor entirely and disable the P0420 code.
Old Feb 18, 2010 | 02:05 PM
midwestX's Avatar
well the shop told me (touge factory IL) that it was already messed up by the dealer earlier which I don't believe
I did had the cat replaced at the dealer due to rattle they changed the cat but might have used the same O2 sensor?
Old Feb 18, 2010 | 02:08 PM
midwestX's Avatar
Well first of all I went to the shop to get AMS dp install. Then they told me they were unable to move stock O2 housing the bolts will break blah blah..and they dethreaded my catalytic O2 sensor
Old Feb 18, 2010 | 02:20 PM
beetle_orange's Avatar
so they still were not able to install it?
Old Feb 18, 2010 | 02:40 PM
midwestX's Avatar
Nope, I mean I am not complaining about the mechanics but man common! They should have hooked me up with something. All they told me was the new sensor from the dealer will cost 400$ something
