4B11T rod failure
Old Mar 11, 2010 | 11:49 AM
  #31
MarkM's Avatar
Originally Posted by JohnBradley
Mark, thanks for putting up with my conjecture. Did you clean the piston then?
yeah, bringing it home didn't go down well at all, had to at least be clean! it's a nice desk ornament now, a reminder not to modify
Originally Posted by Brokenevo
I talked to a diamond star Mitsu tech and he also said sounds like you got water in the engine (hydro locked)
100% not the case!
Old Mar 11, 2010 | 11:53 AM
  #32
MarkM's Avatar
anyone any experience/comments on using CP pistons/BC H beam rods to fix this, I've been offered them at a great price! I'm also using Cosworth Rod Bearings, Cosworth valve springs and Cosworth head gasket.............
Old Mar 11, 2010 | 11:55 AM
  #33
TTP Engineering's Avatar
I would not use Brian Crower anything.
If using an Hbeam, then I believe Manley and Eagle have some. We do not use HBeam rods in any of our racing engines. I beams or aluminums only.
Personally for a lightweight, heavy duty rod, our A1000 Aluminum units definately fit the bill.
https://www.evolutionm.net/forums/ev...ods-build.html
CLICK ON THE PHOTO FOR MORE DETAILS:
Old Mar 11, 2010 | 11:59 AM
  #34
MarkM's Avatar
Thanks for that, Manley turbo tuff I beams are my 1st choice, but the above combination is cheap, so I was tempted!!!!
Old Mar 11, 2010 | 12:37 PM
  #35
murlo26's Avatar
Don't go cheap unless you want a repeat
Old Mar 11, 2010 | 12:38 PM
  #36
We actually have a STD bore 9.0:1 JE pistons on Manley Steel Ibeam complete with JE pro seal rings already "pin fit" and clearanced ready for drop in. We were going to use them for a build but opted for +.20 bore and hone on that build which required the next size up piston.
They are sitting under glass now as art for our Manley Ibeams on our website but it seems they with the std bore pistons would be a perfect fit for you right now.
PM us if you would like to discuss a special deal for the set already pin fit for drop in.
Old Mar 11, 2010 | 02:59 PM
  #37
RotorGlow's Avatar
Way to much timing advance causing severe pre-detonation (bad tune)?
Old Mar 11, 2010 | 03:00 PM
  #38
MarkM's Avatar
no detonation, top of piston is undamaged, plug is undamaged, just oily, ran on this tune for 14 months!
Old Mar 11, 2010 | 03:59 PM
  #39
mlomker's Avatar
Originally Posted by DRAG
There are plenty of guys having rod failures that don't seem to be tune related. That one looks a little odd for sure.
Rod failure on a stock tune? Haven't seen anyone post that one. It's difficult to prove that it wasn't the tune if the car was tuned. Motors also tend to let go some time after the actual damage was done...have heard countless tales along those lines.
Old Mar 11, 2010 | 08:06 PM
  #40
Brokenevo's Avatar
I would be interested in the stock size, not looking to do too much more then just replacing the internals for now!
Old Mar 19, 2010 | 06:33 PM
  #41
rico91stang's Avatar
What rpm was the motor seeing? How much boost? Stock head bolts? Test your coolant to see if any combustion gasses seeped in.
evo4nr
Sep 15, 2025 05:45 PM
Force-Fed Performance
85
Sep 11, 2013 02:21 AM
MarkM
12
Jun 15, 2012 11:04 AM
Sep 25, 2011 07:37 PM
drahte1905
Sep 24, 2010 02:18 PM
