4B11T rod failure
Old Mar 9, 2010 | 02:09 PM
MarkM's Avatar
Thumbs down 4B11T rod failure
28 psi 400 hp no ringland/piston failure, just soft rods, bore is a mess
Old Mar 9, 2010 | 02:16 PM
tsitalon1's Avatar
So how are others getting away with so much more? I've read of many with more power on stock bottom end, huh?
Were you logging? Could this be the result of knock in anyway?
Was this 400hp at the wheels?
Old Mar 9, 2010 | 02:17 PM
HR2L's Avatar
Ouch! Game Over for that Rod!
How much WHP were you making? Sad shame...Looks like its time for Manley Rods!
Old Mar 9, 2010 | 02:28 PM
Phantom X Evo's Avatar
I am sorry to hear about that. It seems odd.
His sig says 395.5 Bhp, so maybe 350 whp.
Old Mar 9, 2010 | 02:32 PM
MarkM's Avatar
Correct it's flywheel hp, but it's UK BHP so our figures aren't exactly comparable
Not logging, I know I was on the lean side, but not dangerously so, it was booked in tomorrow to have the fueling sorted with a walbro and a map tweak Now I'm in a world of hurt
Old Mar 9, 2010 | 03:41 PM
bremboy's Avatar
That really sucks.
Old Mar 9, 2010 | 03:58 PM
Fourdoor's Avatar
Not logging, I knowI was on the lean side, but not dangerously so, it was booked in tomorrow to have the fueling sorted with a walbro and a map tweak Now I'm in a world of hurt
Ummm, change the "I know" to "I thought"
Sorry to see the damage done Hope you get her back up and running soon.
Keith
Old Mar 9, 2010 | 04:03 PM
DOMINIC1's Avatar
Well, now you have a kick *** paper weight!
Old Mar 9, 2010 | 04:05 PM
MarkM's Avatar
yeah, looks great on my desk, need it mounted properly, every time I want to mod I'll just look at it to remind me to stay stock
Old Mar 9, 2010 | 05:29 PM
tsitalon1's Avatar
Yeah, I know but that doesn't make sense really UNLESS he was knocking....So without proof I'm attributing this to knock...
Old Mar 9, 2010 | 05:49 PM
mlomker's Avatar
Most of the failures that I've seen were tune-related. The learning curve for tuners involves blown engines...
Old Mar 9, 2010 | 06:08 PM
JohnBradley's Avatar
Bent rod versus a rod that gets kicked out the block like the VIII and IX is interesting. Tells me the metallurgy has changed some and is now more like a Honda or 1G DSM. Bending a rod is relative to cylinder pressue.
This is expressed normally as torque of course and in the 4G63 is typically around 400 ft lbs as a safe limit. I am curious Mark what fuel this was on? There is no sign of detonation so I am thinking it was probably pretty good. Any methanol injection? I am wondering if you were past MBT and didnt know it (or your tuner didnt) and the rod failed from that or this was a fluke however unfortunate.
We have been around stock bottom Xs that have made far more torque and not failed so its curious as to why this happened this way.
aaron
Old Mar 9, 2010 | 06:10 PM
spdracerut's Avatar
Yeah, this is quite curious. Don't really see much signs of detonation on the top of the piston.
Old Mar 9, 2010 | 06:51 PM
Brokenevo's Avatar
how did you find this out? were there engine noises? did you also check the crank to see if there is any crank damage? Was also wondering about meth. Were you on stock turbo?
Old Mar 9, 2010 | 07:03 PM
TTP Engineering's Avatar
aaron
Shows the symptoms of a hydrolocked engine.
